It seems that KTL-3PH- line is closed to KTLX line and current sn23x thing may be a mix for them, where there should be separate thing definitions.
I have scratched a debug thing for such case, in which you can test specific modbus addresses exposed by an inverter. You may look it through issues on github repo for this project. Or wait until I publish new version on the third party marketplace.
thank you, I have not found the related issue in git. Anyway what should be the testing scenario?
What dou you mean by"modbus addresses exposed by inverter"?
Sorry,maybe I got it, modbus addresses like registers for reading values (items) right?
What debug info should I reply back to you?
In upcoming week or two I will make a release with debug thing and some manual how to tinker with it. The code is written and tested, but no manual and release right now for this.
With this debug thing you will be able to test some configuration and hopefully map your inverters / loggers / firmware mashup onto something called modbus registers. When those modbus registers would be known for your PV setup - we may much easily create things specific to your setup.
reported the debug thing output for regs:
0x0404 | 0x0420
and model: Sofar HYD 10KTL-3PH-PRO on Git: Git issue.
Plz let me know if I should test more.
Thanks once more.
