This binding was initially developed for an NAD T-787 A/V Receiver. I have added support for a few other receivers and am interested to find out if there are others in the community that would benefit from having this binding published in a future OpenHab release.
Supported models include:
Serial models T-765, T-775, T-785 using an Ethernet to RS232 converter (for example Global Cache’s WF2SL, IT2SL, USR IOT’s USR-TCP232-302, etc)
Direct Ethernet connected models T-187, T-777, T-787
A generic model is included with the assumption it works with NAD’s command protocol
This binding has been tested on the latest stable release of OH (3.2.0), Milestone 3.3.0M1 and OH3.3.0-SNAPSHOT - running on both RPI and Windows systems using the NAD T-787 Surround Sound Receiver over a direct Ethernet connection, including an XM Direct Home Tuner connected to the T-787.
If interested in testing this binding, you can find the jar file in the release note here: NAD A/V Receiver Binding. Simply download from the assets section of the release note and copy into the addons folder on your OH3 system.
All feedback is greatly appreciated…
Readme
Refer to the README for additional details regarding the configuration of this binding.
If you move this topic to the Marketplace Bundles category and add a link to the jar file. People will be able to install the binding directly from within openHAB main ui marketplace bindings. (If you add the logo to the top of this topic that will also show up nicely as the logo image in the openHAB ui)
@dschoepel , thank you for putting this together!
Any hints on enabling debug output for the binding?
Tried to connect to my T763 with Ethernet/Serial bridge and no luck.
I configured the thing manually because the bridge is using a non-standard port.
The thing is shown as being online, but no communication is coming back or forth.
Ideas?
Good to hear that your connection goes on-line. Couple suggestions…
Validate That NAD Command Protocol Is Used By Your Receiver
You should try to connect using telnet from a PC. Putty is a good client to connect with. Basic setting should look like:
Once connected, you should be able to send a command and receive a response. A very common command would be Main.Power? , hit “return” to send.
If you get a response back (it will look like Main.Power=On or Main.Power=Off); then we know that your receiver can accept commands and respond to them over your bridge.
A list of the NAD commands can be found at the bottom of the READ.ME for the binding. If a command is not recognized by the receiver, it will not send anything back…
If this does not work, it’s likely that one of two things is happening:
The command protocol is different than what is being used by the binding - or-
The bridge is not set up correctly so that responses are coming back from the receiver
I suspect the binding is sending commands, but nothing is being received by the binding that matches a supported command.
Thank you @dschoepel , you just answered my question, unfortunately this is not going to work for T763, it uses a completely different set of serial commands… Back to using my hacked MQTT bridge code I guess.
Save the file and then restart with sudo service ser2net restart
At this point it’s possible to test the ser2net connection is working by running putty or telnet and connecting like the following…
telnet openhab-berry-01 4445
Trying 192.168.7.90...
Connected to openhab-berry-01.local.lan.
Escape character is '^]'.
Main.Power? <- type this command and then press Enter
Main.Power=Off <- this is the reply from the AVR
Go into OpenHAB 3 and search for and install the NAD binding.
Add a thing and choose one of the Serial connected AVRs.
Configure the IP as the IP of the Raspberry-PI and using the port defined above (4445 in my case).
Going back into the Thing in OH3, when I click on the Code tab, my thing config looks like this…
Thanks @netwolfuk for giving the NAD binding a try. Glad you had some success and thanks for sharing the details around how you got the serial to IP connection working. Let me know if you have any issues I can help with.
