@ramack
Hi, I am also very new in this and trying to get to grips with Openhab ā¦
To apply the the binding you just need to copy it to the openhab share addons directory and it should pull it in.
I have a different issue with the Resol binding listed further up in the trail (org.openhab.binding.resol_2.0.0.201708241721.jar).
It looks like my controller BX Plus is not referenced in the resolhandler.java as mentioned by @Howdyā¦
I have been trying to get my head around Eclipse, editing and re-compiling to include my controller but failing miserably (although IT background i have no idea about programming). I tried to get the Eclipse environment setup but I am getting lost in trying to add that Resol binding and exporting it as a JAR file.
Would somebody be so kind and help me getting through the steps or, as a Christmas present, do it for me (just the first 4 sensors and relays would do)
This is what I am seeing in the log files for the controller (interestingly the last line ālastupdateā is working)
2017-12-21 01:29:40.571 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_000_2_0, Name: Temperatur Sensor 1, Raw: 10.3, Text: 10.3 Ā°C
2017-12-21 01:29:40.574 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_000_2_0 with name Temperatur Sensor 1 and value 10.3 Ā°C
2017-12-21 01:29:40.576 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_002_2_0, Name: Temperatur Sensor 2, Raw: 18.0, Text: 18.0 Ā°C
2017-12-21 01:29:40.578 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_002_2_0 with name Temperatur Sensor 2 and value 18.0 Ā°C
2017-12-21 01:29:40.580 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_004_2_0, Name: Temperatur Sensor 3, Raw: 47.300000000000004, Text: 47.3 Ā°C
2017-12-21 01:29:40.581 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_004_2_0 with name Temperatur Sensor 3 and value 47.3 Ā°C
2017-12-21 01:29:40.584 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_006_2_0, Name: Temperatur Sensor 4, Raw: 888.8000000000001, Text: 888.8 Ā°C
2017-12-21 01:29:40.585 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_006_2_0 with name Temperatur Sensor 4 and value 888.8 Ā°C
2017-12-21 01:29:40.642 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_040_1_0, Name: Relais 1, Raw: 0.0, Text: 0%
2017-12-21 01:29:40.644 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_040_1_0 with name Relais 1 and value 0%
2017-12-21 01:29:40.646 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_041_1_0, Name: Relais 2, Raw: 0.0, Text: 0%
2017-12-21 01:29:40.648 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_041_1_0 with name Relais 2 and value 0%
2017-12-21 01:29:40.650 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_042_1_0, Name: Relais 3, Raw: 0.0, Text: 0%
2017-12-21 01:29:40.651 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_042_1_0 with name Relais 3 and value 0%
2017-12-21 01:29:40.653 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_043_1_0, Name: Relais 4, Raw: 0.0, Text: 0%
2017-12-21 01:29:40.655 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_043_1_0 with name Relais 4 and value 0%
2017-12-21 01:29:40.657 [INFO ] [nding.resol.internal.IPBridgeHandler] - Id: 00_0010_7112_10_0100_044_1_0, Name: Relais 5, Raw: 0.0, Text: 0%
2017-12-21 01:29:40.658 [WARN ] [b.binding.resol.handler.resolHandler] - No channel available for ID 00_0010_7112_10_0100_044_1_0 with name Relais 5 and value 0%
Another question, why is that binding not included as the other ones are?
Thanks in advance for any help or suggestions!
