i’m writing a new Binding and i have a short question. How can i change the name of “Value” and “Switch”?
All Channels have the same name.This is my thing-types.xml… Did i miss a Description or somthing else?
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="timetree"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="https://openhab.org/schemas/thing-description/v1.0.0"
xsi:schemaLocation="https://openhab.org/schemas/thing-description/v1.0.0 https://openhab.org/schemas/thing-description-1.0.0.xsd">
<bridge-type id="account">
<label>TimeTree Account</label>
<description>TimeTree Account</description>
<config-description>
<parameter name="personalAccessToken" type="text" required="true">
<label>Personal Access Token</label>
<description><![CDATA[The Personal Access Token, created by TimeTree. Look at https://timetreeapp.com/personal_access_tokens]]></description>
</parameter>
<parameter name="refresh" type="integer" unit="min" min="15">
<default>30</default>
<label>Refresh in Minutes</label>
<description>Time between to API requests in minutes. Minimum 15 minutes.</description>
</parameter>
</config-description>
</bridge-type>
<thing-type id="calendar">
<supported-bridge-type-refs>
<bridge-type-ref id="account"/>
</supported-bridge-type-refs>
<label>Calendar</label>
<description>Calendar</description>
<channel-groups>
<channel-group id="calendarDetails" typeId="calendarDetails">
<label>Calendar Details</label>
</channel-group>
<channel-group id="event1" typeId="event">
<label>Event 1</label>
</channel-group>
<channel-group id="event2" typeId="event">
<label>Event 2</label>
</channel-group>
<channel-group id="event3" typeId="event">
<label>Event 3</label>
</channel-group>
<channel-group id="event4" typeId="event">
<label>Event 4</label>
</channel-group>
<channel-group id="event5" typeId="event">
<label>Event 5</label>
</channel-group>
<channel-group id="event6" typeId="event">
<label>Event 6</label>
</channel-group>
<channel-group id="event7" typeId="event">
<label>Event 7</label>
</channel-group>
<channel-group id="event8" typeId="event">
<label>Event 8</label>
</channel-group>
<channel-group id="event9" typeId="event">
<label>Event 9</label>
</channel-group>
<channel-group id="event10" typeId="event">
<label>Event 10</label>
</channel-group>
</channel-groups>
</thing-type>
<channel-group-type id="calendarDetails">
<description>Details of the Calendar</description>
<channels>
<channel id="calendarName" typeId="calendarName"/>
</channels>
</channel-group-type>
<channel-group-type id="event">
<label>Event</label>
<description>This is a Event-Channel</description>
<channels>
<channel id="category" typeId="category" />
<channel id="title" typeId="title" />
<channel id="allDay" typeId="allDay" />
<channel id="startAt" typeId="startAt" />
<channel id="startTimeZone" typeId="startTimeZone" />
<channel id="endAt" typeId="endAt" />
<channel id="endTimeZone" typeId="endTimeZone" />
<channel id="description" typeId="description" />
<channel id="location" typeId="location" />
<channel id="url" typeId="url" />
<channel id="updatedAt" typeId="updatedAt" />
<channel id="createdAt" typeId="createdAt" />
</channels>
<channel-type id="category">
<item-type>String</item-type>
<label>Category</label>
<description>Category of the Event</description>
<state readOnly="true"/>
</channel-type>
<channel-type id="title">
<label>Title</label>
<description>Title of the Event</description>
</channel-type>
<channel-type id="allDay">
<item-type>Switch</item-type>
<label>All-Day</label>
<description>All-Day Event.</description>
</channel-type>
<channel-type id="startAt">
<item-type>DateTime</item-type>
<label>Start-Time</label>
<description>Start time of the Event.</description>
</channel-type>
<channel-type id="startTimeZone">
<label>Start-Time-Timezone</label>
<description>Timezone of the Event start.</description>
</channel-type>
<channel-type id="endAt">
<label>End-Time</label>
</channel-type>
<channel-type id="endTimeZone">
<label>End-Time-Timezone</label>
<description>Timezone of the Event end.</description>
</channel-type>
<channel-type id="description">
<label>Description</label>
<description>Textual description of the Event.</description>
</channel-type>
<channel-type id="location">
<label>Location</label>
<description>The Country of the Event.</description>
</channel-type>
<channel-type id="url">
<label>Url</label>
<description>Optional URL of the Event.</description>
</channel-type>
<channel-type id="updatedAt">
<label>Updated-At</label>
<description>Update time of the Event.</description>
</channel-type>
<channel-type id="createdAt">
<label>Created-At</label>
<description>Create time of the Event.</description>
</channel-type>
<channel-type id="calendarName">
<description>Textual description of the warning.</description>
</channel-type>
<channel-type id="updates">
<kind>trigger</kind>
<label>Updated</label>
<description></description>
<event>
<options>
<option value="NEW">New</option>
</options>
</event>
</channel-type>
</thing:thing-descriptions>
