here are some logs, only including a few minutes to reduce noise. node 4 is my hallway light switch, i can send it commands and control it fine, but manual events dont seem to make it back:
2022-10-07 22:00:22.993 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DrivewayFloodlight_MotionAlarm' changed from ON to OFF
2022-10-07 22:00:56.853 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DrivewayFloodlight_MotionAlarm' changed from OFF to ON
2022-10-07 22:03:46.393 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Hallway_Dimmer' received command 87
2022-10-07 22:03:46.395 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Hallway_Dimmer' predicted to become 87
2022-10-07 22:03:46.395 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hallway_Dimmer' changed from 64 to 87
2022-10-07 22:04:32.996 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DrivewayFloodlight_MotionAlarm' changed from ON to OFF
2022-10-07 22:05:22.116 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DrivewayFloodlight_MotionAlarm' changed from OFF to ON
2022-10-07 22:00:22.987 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 1B 0A 71 05 00 00 00 FF 07 00 01 08 7F
2022-10-07 22:00:22.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0A 71 05 00 00 00 FF 07 00 01 08
2022-10-07 22:00:22.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0A 71 05 00 00 00 FF 07 00 01 08
2022-10-07 22:00:22.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:00:22.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:00:22.992 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:00:22.992 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-10-07 22:00:22.992 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-10-07 22:00:22.992 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2022-10-07 22:00:22.992 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: NOTIFICATION report - 0 = 0, event=0, status=255, plen=1
2022-10-07 22:00:22.992 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: Alarm Type = BURGLAR (0)
2022-10-07 22:00:22.992 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-10-07 22:00:22.992 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-10-07 22:00:22.992 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:00:22.993 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter NOTIFICATION event is 0, type OnOffType
2022-10-07 22:00:22.993 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:00:22.993 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:alarm_motion to OFF [OnOffType]
2022-10-07 22:00:22.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:00:22.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@725394c0.
2022-10-07 22:00:22.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:00:22.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:22.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:00:33.199 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 0F 02 84 07 7D
2022-10-07 22:00:33.204 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 02 84 07
2022-10-07 22:00:33.204 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 02 84 07
2022-10-07 22:00:33.204 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:00:33.204 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DONE)
2022-10-07 22:00:33.204 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: resetResendCount initComplete=true isDead=false
2022-10-07 22:00:33.204 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Is awake with 0 messages in the queue, state DONE
2022-10-07 22:00:33.204 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - awakeMax for this Timer Task 40 in 0.5 second intervals
2022-10-07 22:00:33.204 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Start sleep timer with 500ms interval
2022-10-07 22:00:33.204 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2022-10-07 22:00:33.205 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 15: Node Status event - Node is AWAKE
2022-10-07 22:00:33.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2022-10-07 22:00:33.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@185917aa.
2022-10-07 22:00:33.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:00:33.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:33.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:00:33.424 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 0F 02 84 07 7D
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 02 84 07
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 02 84 07
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DONE)
2022-10-07 22:00:33.429 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: resetResendCount initComplete=true isDead=false
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@46dbc6b9.
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:33.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:00:33.628 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 0F 02 84 07 7D
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 02 84 07
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 02 84 07
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DONE)
2022-10-07 22:00:33.633 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: resetResendCount initComplete=true isDead=false
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2e3a5208.
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:33.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:00:33.705 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 0 Messages waiting, state DONE count 1
2022-10-07 22:00:33.705 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Go back to sleep, state DONE, count 1 messages 0
2022-10-07 22:00:33.705 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2022-10-07 22:00:33.705 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2022-10-07 22:00:33.705 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2022-10-07 22:00:33.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@32f67e1c
2022-10-07 22:00:33.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 904 priority from Immediate to Immediate
2022-10-07 22:00:33.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2022-10-07 22:00:33.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 904 to queue - size 7
2022-10-07 22:00:33.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:00:33.705 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 0F 02 84 08 25 B1 F0
2022-10-07 22:00:33.705 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 08 25 B1 F0
2022-10-07 22:00:33.707 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-10-07 22:00:33.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:00:33.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:00:33.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:00:33.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-10-07 22:00:33.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:33.711 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2022-10-07 22:00:33.716 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-10-07 22:00:33.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 904: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 177
2022-10-07 22:00:33.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 904: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 177
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 904: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 177
2022-10-07 22:00:33.719 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:00:33.719 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 904: Advanced to WAIT_REQUEST
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 904: Transaction not completed
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:33.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:00:38.719 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 904: Timeout at state WAIT_REQUEST. 3 retries remaining.
2022-10-07 22:00:38.720 [DEBUG] [sactionManager$ZWaveTransactionTimer] - Aborting Transaction!
2022-10-07 22:00:38.720 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 904: Transaction ABORTED
2022-10-07 22:00:38.720 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
2022-10-07 22:00:38.720 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
2022-10-07 22:00:38.721 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-10-07 22:00:38.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:00:38.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:00:38.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 904: [ABORTED] priority=Immediate, requiresResponse=true, callback: 177
2022-10-07 22:00:38.722 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-10-07 22:00:38.722 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:38.723 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-10-07 22:00:38.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:00:41.431 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 B1 01 59
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=1, callback=177, payload=B1 01
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=1, callback=177, payload=B1 01
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 904: [ABORTED] priority=Immediate, requiresResponse=true, callback: 177
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 904: [ABORTED] priority=Immediate, requiresResponse=true, callback: 177
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 904: (Callback 177)
2022-10-07 22:00:41.436 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 904: callback 177
2022-10-07 22:00:41.436 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=1, callback=177, payload=B1 01
2022-10-07 22:00:41.436 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 177, Status = Transmission complete, no ACK received(1)
2022-10-07 22:00:41.436 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 904: Transaction not completed
2022-10-07 22:00:41.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:41.437 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:00:50.720 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 904: Timeout at state ABORTED. 3 retries remaining.
2022-10-07 22:00:50.720 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 904: Transaction is current transaction, so clearing!!!!!
2022-10-07 22:00:50.720 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 904: Transaction CANCELLED
2022-10-07 22:00:50.720 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-10-07 22:00:50.720 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:904 CANCELLED
2022-10-07 22:00:50.720 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:00:50.720 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 904: Transaction event listener: DONE: CANCELLED -> ABORTED
2022-10-07 22:00:50.721 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Went to sleep COMPLETE
2022-10-07 22:00:56.847 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 1B 09 71 05 00 00 00 FF 07 08 00 62
2022-10-07 22:00:56.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:00:56.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:00:56.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:00:56.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:00:56.853 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:00:56.853 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-10-07 22:00:56.853 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-10-07 22:00:56.853 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2022-10-07 22:00:56.853 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2022-10-07 22:00:56.853 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: Alarm Type = BURGLAR (0)
2022-10-07 22:00:56.853 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-10-07 22:00:56.853 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-10-07 22:00:56.853 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:00:56.853 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter NOTIFICATION event is 8, type OnOffType
2022-10-07 22:00:56.853 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:alarm_motion to ON [OnOffType]
2022-10-07 22:00:56.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:00:56.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4021269b.
2022-10-07 22:00:56.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:00:56.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:00:56.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:01:27.479 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 22 06 31 05 03 0A 00 FA 14
2022-10-07 22:01:27.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=34, callback=0, payload=00 22 06 31 05 03 0A 00 FA
2022-10-07 22:01:27.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=34, callback=0, payload=00 22 06 31 05 03 0A 00 FA
2022-10-07 22:01:27.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:01:27.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 34: Application Command Request (ALIVE:DONE)
2022-10-07 22:01:27.484 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 34: resetResendCount initComplete=true isDead=false
2022-10-07 22:01:27.484 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 34: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2022-10-07 22:01:27.484 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 34: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2022-10-07 22:01:27.484 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 34: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT
2022-10-07 22:01:27.484 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 34: Sensor Type = Luminance(3), Scale = 1
2022-10-07 22:01:27.484 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 34: Sensor Value = 2.5E+2
2022-10-07 22:01:27.484 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 34: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2022-10-07 22:01:27.484 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 34: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=2.5E+2
2022-10-07 22:01:27.484 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 34: Updating channel state zwave:device:zwave-controller:node34:sensor_luminance to 250 lx [QuantityType]
2022-10-07 22:01:27.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 34: Commands processed 1.
2022-10-07 22:01:27.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 34: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10158d72.
2022-10-07 22:01:27.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:01:27.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:01:27.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:01:45.989 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 1B 09 71 05 00 00 00 FF 07 08 00 62
2022-10-07 22:01:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:01:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:01:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:01:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:01:45.994 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:01:45.994 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-10-07 22:01:45.994 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-10-07 22:01:45.994 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2022-10-07 22:01:45.995 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2022-10-07 22:01:45.995 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: Alarm Type = BURGLAR (0)
2022-10-07 22:01:45.995 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-10-07 22:01:45.995 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-10-07 22:01:45.995 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:01:45.995 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter NOTIFICATION event is 8, type OnOffType
2022-10-07 22:01:45.995 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:alarm_motion to ON [OnOffType]
2022-10-07 22:01:45.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:01:45.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@8e37fc7.
2022-10-07 22:01:45.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:01:45.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:01:45.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:02:43.879 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 1B 09 71 05 00 00 00 FF 07 08 00 62
2022-10-07 22:02:43.883 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:02:43.883 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:02:43.883 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:02:43.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:02:43.884 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:02:43.884 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-10-07 22:02:43.884 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-10-07 22:02:43.884 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2022-10-07 22:02:43.884 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2022-10-07 22:02:43.884 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: Alarm Type = BURGLAR (0)
2022-10-07 22:02:43.884 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-10-07 22:02:43.884 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-10-07 22:02:43.884 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:02:43.884 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter NOTIFICATION event is 8, type OnOffType
2022-10-07 22:02:43.884 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:alarm_motion to ON [OnOffType]
2022-10-07 22:02:43.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:02:43.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7435d6c1.
2022-10-07 22:02:43.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:02:43.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:02:43.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:03:32.990 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 1B 09 71 05 00 00 00 FF 07 08 00 62
2022-10-07 22:03:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:03:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:03:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:03:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:03:32.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:03:32.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-10-07 22:03:32.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-10-07 22:03:32.995 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2022-10-07 22:03:32.996 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2022-10-07 22:03:32.996 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: Alarm Type = BURGLAR (0)
2022-10-07 22:03:32.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-10-07 22:03:32.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-10-07 22:03:32.996 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:03:32.996 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter NOTIFICATION event is 8, type OnOffType
2022-10-07 22:03:32.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:alarm_motion to ON [OnOffType]
2022-10-07 22:03:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:03:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d692322.
2022-10-07 22:03:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:03:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:03:46.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:zwave-controller:node4:switch_dimmer --> 87 [PercentType]
2022-10-07 22:03:46.397 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Creating new message for command SWITCH_MULTILEVEL_SET
2022-10-07 22:03:46.397 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
2022-10-07 22:03:46.397 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2022-10-07 22:03:46.397 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Adding to device queue
2022-10-07 22:03:46.397 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Added 905 to queue - size 7
2022-10-07 22:03:46.397 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:03:46.397 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 04 03 26 01 57 25 B2 06
2022-10-07 22:03:46.397 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 26 01 57 25 B2 06
2022-10-07 22:03:46.399 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-10-07 22:03:46.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:03:46.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:03:46.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:03:46.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-10-07 22:03:46.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:46.403 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2022-10-07 22:03:46.408 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-10-07 22:03:46.408 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 905: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 178
2022-10-07 22:03:46.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:03:46.409 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling initialised at 86400 seconds - start in 1500 milliseconds.
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 905: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 178
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 905: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 178
2022-10-07 22:03:46.412 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:03:46.412 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 4: sentData successfully placed on stack.
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 905: Advanced to WAIT_REQUEST
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: TID 905: Transaction not completed
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:46.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:03:46.460 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 B2 00 5B
2022-10-07 22:03:46.464 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=178, payload=B2 00
2022-10-07 22:03:46.464 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=178, payload=B2 00
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 905: [WAIT_REQUEST] priority=Set, requiresResponse=true, callback: 178
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 905: [WAIT_REQUEST] priority=Set, requiresResponse=true, callback: 178
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 905: (Callback 178)
2022-10-07 22:03:46.465 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 905: callback 178
2022-10-07 22:03:46.465 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=178, payload=B2 00
2022-10-07 22:03:46.465 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 4: SendData Request. CallBack ID = 178, Status = Transmission complete and ACK received(0)
2022-10-07 22:03:46.465 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
2022-10-07 22:03:46.465 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 905: Transaction COMPLETED
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Response processed after 57ms
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: TID 905: Transaction completed
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: notifyTransactionResponse TID:905 DONE
2022-10-07 22:03:46.465 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:46.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:03:47.909 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling...
2022-10-07 22:03:47.909 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling zwave:device:zwave-controller:node4:switch_dimmer
2022-10-07 22:03:47.909 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 4: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2022-10-07 22:03:47.909 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Creating new message for command SWITCH_MULTILEVEL_GET
2022-10-07 22:03:47.909 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
2022-10-07 22:03:47.909 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2022-10-07 22:03:47.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Adding to device queue
2022-10-07 22:03:47.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Added 906 to queue - size 7
2022-10-07 22:03:47.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:03:47.909 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 04 02 26 02 25 B3 51
2022-10-07 22:03:47.909 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 4: Sending REQUEST Message = 01 09 00 13 04 02 26 02 25 B3 51
2022-10-07 22:03:47.911 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-10-07 22:03:47.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:03:47.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-10-07 22:03:47.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:03:47.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-10-07 22:03:47.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:47.915 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2022-10-07 22:03:47.920 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-10-07 22:03:47.920 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 906: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 179
2022-10-07 22:03:47.921 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:03:47.923 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:03:47.923 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:03:47.923 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 906: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 179
2022-10-07 22:03:47.923 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-10-07 22:03:47.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 906: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 179
2022-10-07 22:03:47.924 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-10-07 22:03:47.924 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 4: sentData successfully placed on stack.
2022-10-07 22:03:47.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 906: Advanced to WAIT_REQUEST
2022-10-07 22:03:47.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: TID 906: Transaction not completed
2022-10-07 22:03:47.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:47.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:03:47.977 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 B3 00 5A
2022-10-07 22:03:47.981 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=179, payload=B3 00
2022-10-07 22:03:47.981 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=179, payload=B3 00
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 906: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 179
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 906: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 179
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 906: (Callback 179)
2022-10-07 22:03:47.982 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 906: callback 179
2022-10-07 22:03:47.982 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=179, payload=B3 00
2022-10-07 22:03:47.982 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 4: SendData Request. CallBack ID = 179, Status = Transmission complete and ACK received(0)
2022-10-07 22:03:47.982 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 906: Advanced to WAIT_DATA
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: TID 906: Transaction not completed
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:47.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-10-07 22:03:48.052 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 04 05 26 03 57 57 00 D4
2022-10-07 22:03:48.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=0, payload=00 04 05 26 03 57 57 00
2022-10-07 22:03:48.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=0, payload=00 04 05 26 03 57 57 00
2022-10-07 22:03:48.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:03:48.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
2022-10-07 22:03:48.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
2022-10-07 22:03:48.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2022-10-07 22:03:48.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
2022-10-07 22:03:48.058 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2022-10-07 22:03:48.058 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 87
2022-10-07 22:03:48.058 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2022-10-07 22:03:48.058 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=87
2022-10-07 22:03:48.058 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:zwave-controller:node4:switch_dimmer to 87 [PercentType]
2022-10-07 22:03:48.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
2022-10-07 22:03:48.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12b57e0.
2022-10-07 22:03:48.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12b57e0.
2022-10-07 22:03:48.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: notifyTransactionResponse TID:906 DONE
2022-10-07 22:03:48.058 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-10-07 22:03:48.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-10-07 22:03:48.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:03:48.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:48.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:03:52.977 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 1B 06 31 05 03 0A 00 FA 2D
2022-10-07 22:03:52.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 06 31 05 03 0A 00 FA
2022-10-07 22:03:52.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 06 31 05 03 0A 00 FA
2022-10-07 22:03:52.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:03:52.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:03:52.983 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:03:52.983 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2022-10-07 22:03:52.983 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2022-10-07 22:03:52.983 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT
2022-10-07 22:03:52.983 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 27: Sensor Type = Luminance(3), Scale = 1
2022-10-07 22:03:52.983 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 27: Sensor Value = 2.5E+2
2022-10-07 22:03:52.983 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2022-10-07 22:03:52.983 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=2.5E+2
2022-10-07 22:03:52.983 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:sensor_luminance to 250 lx [QuantityType]
2022-10-07 22:03:52.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:03:52.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12a51d45.
2022-10-07 22:03:52.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:03:52.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:03:52.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:04:32.991 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 1B 0A 71 05 00 00 00 FF 07 00 01 08 7F
2022-10-07 22:04:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0A 71 05 00 00 00 FF 07 00 01 08
2022-10-07 22:04:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0A 71 05 00 00 00 FF 07 00 01 08
2022-10-07 22:04:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:04:32.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:04:32.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:04:32.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-10-07 22:04:32.996 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-10-07 22:04:32.996 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2022-10-07 22:04:32.996 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: NOTIFICATION report - 0 = 0, event=0, status=255, plen=1
2022-10-07 22:04:32.996 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: Alarm Type = BURGLAR (0)
2022-10-07 22:04:32.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-10-07 22:04:32.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-10-07 22:04:32.996 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:04:32.996 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter NOTIFICATION event is 0, type OnOffType
2022-10-07 22:04:32.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:alarm_motion to OFF [OnOffType]
2022-10-07 22:04:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:04:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@487c420e.
2022-10-07 22:04:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:04:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:04:32.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-10-07 22:05:22.110 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 1B 09 71 05 00 00 00 FF 07 08 00 62
2022-10-07 22:05:22.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:05:22.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 09 71 05 00 00 00 FF 07 08 00
2022-10-07 22:05:22.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-10-07 22:05:22.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2022-10-07 22:05:22.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2022-10-07 22:05:22.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-10-07 22:05:22.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-10-07 22:05:22.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2022-10-07 22:05:22.115 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2022-10-07 22:05:22.115 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 27: Alarm Type = BURGLAR (0)
2022-10-07 22:05:22.115 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-10-07 22:05:22.116 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-10-07 22:05:22.116 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter processing NOTIFICATION
2022-10-07 22:05:22.116 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 27: Alarm converter NOTIFICATION event is 8, type OnOffType
2022-10-07 22:05:22.116 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:zwave-controller:node27:alarm_motion to ON [OnOffType]
2022-10-07 22:05:22.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2022-10-07 22:05:22.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3cf80810.
2022-10-07 22:05:22.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-10-07 22:05:22.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-10-07 22:05:22.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
during this period, i manually turned on the switch, then used OH to adjust dimmer, then manually changed dimmer value. i think i only see 1 set of events for the outgoing in the logs.
