Hallo Querdenker2k,
thanks for the link to the updated version. I downloaded and copied it to my OH-Installation.
Yes, the config is the same. For testing I enabled 3 calendar accounts. One from gmail and two from blaucloud.de.
OH.cfg:
caldavio:gmail:url=https://www.google.com/calendar/dav/haeuselesteini@gmail.com/events
caldavio:gmail:disableCertificateVerification=true
caldavio:gmail:username=user
caldavio:gmail:password=pw
caldavio:gmail:reloadInterval=500
caldavio:gmail:preloadTime=20000
caldavio:gmail:historicLoadTime=1440
caldavio:haeusele:url=https://haeusele.blaucloud.de/remote.php/caldav/calendars/haeusele/allgemein?export
caldavio:haeusele:user=user
caldavio:haeusele:password=pw
caldavio:haeusele:reloadInterval=5
caldavio:haeusele:preloadTime=28800
caldavio:haeusele:historicLoadTime=1440
caldavio:haeusele:disableCertificateVerification=true
caldavio:timeZone=Europe/Berlin
caldavio:muell:url=https://haeusele.blaucloud.de/remote.php/caldav/calendars/haeusele/muell?export
caldavio:muell:user=user
caldavio:muell:password=pw
caldavio:muell:reloadInterval=60
caldavio:muell:preloadTime=28800
caldavio:muell:disableCertifiateVerification=true
caldavCommand:readCalendars=haeusele,muell,gmail
caldavPersonal:usedCalendars=haeusele,muell,gmail
Log looks like this:
2016-06-19 13:04:27.967 [DEBUG] [o.i.c.internal.CalDavActivator] - CalDav Calendar IO has been started.
2016-06-19 13:04:28.046 [INFO ] [rtuna.ical4j.util.Configurator] - ical4j.properties not found.
2016-06-19 13:04:28.048 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: gmail:disableCertificateVerification
2016-06-19 13:04:28.056 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: gmail:historicLoadTime
2016-06-19 13:04:28.057 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: gmail:password
2016-06-19 13:04:28.058 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: gmail:preloadTime
2016-06-19 13:04:28.059 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: gmail:reloadInterval
2016-06-19 13:04:28.060 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: gmail:url
2016-06-19 13:04:28.060 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: gmail:username
2016-06-19 13:04:28.061 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: haeusele:disableCertificateVerification
2016-06-19 13:04:28.062 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: haeusele:historicLoadTime
2016-06-19 13:04:28.062 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: haeusele:password
2016-06-19 13:04:28.063 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: haeusele:preloadTime
2016-06-19 13:04:28.064 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: haeusele:reloadInterval
2016-06-19 13:04:28.065 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: haeusele:url
2016-06-19 13:04:28.066 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: haeusele:user
2016-06-19 13:04:28.066 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: muell:disableCertifiateVerification
2016-06-19 13:04:28.067 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: muell:password
2016-06-19 13:04:28.068 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: muell:preloadTime
2016-06-19 13:04:28.069 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: muell:reloadInterval
2016-06-19 13:04:28.069 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: muell:url
2016-06-19 13:04:28.070 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: muell:user
2016-06-19 13:04:28.071 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: service.pid
2016-06-19 13:04:28.072 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: timeZone
2016-06-19 13:04:28.073 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - overriding default timezone Europe/Berlin with Europe/Berlin
2016-06-19 13:04:28.074 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - found timeZone: Europe/Berlin
2016-06-19 13:04:28.075 [TRACE] [.i.c.internal.CalDavLoaderImpl] - config for id ‘gmail’: CalDavConfig [key=gmail, username=user, password=pw, url=https://www.google.com/calendar/dav/user@gmail.com/events, reloadMinutes=500, preloadMinutes=20000, disableCertificateVerification=true, lastModifiedFileTimeStampValid=true]
2016-06-19 13:04:28.451 [DEBUG] [o.i.c.internal.CalDavActivator] - CalDav Calendar IO has been started.
2016-06-19 13:04:28.550 [DEBUG] [o.b.c.internal.CalDavActivator] - CalDav-Presence binding has been started.
2016-06-19 13:04:28.555 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config: calendar:muell type:EVENT eventNr:1 value:START
2016-06-19 13:04:28.556 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: calendar:muell
2016-06-19 13:04:28.558 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: type:EVENT
2016-06-19 13:04:28.559 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: eventNr:1
2016-06-19 13:04:28.560 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: value:START
2016-06-19 13:04:28.561 [TRACE] [.c.i.CalDavBindingProviderImpl] - found values: calendar=[muell], type=EVENT, eventNr=1, value=START
2016-06-19 13:04:28.565 [DEBUG] [.c.i.CalDavBindingProviderImpl] - adding item: Cal_Event1_Start
2016-06-19 13:04:28.566 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config: calendar:muell type:EVENT eventNr:1 value:End
2016-06-19 13:04:28.567 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: calendar:muell
2016-06-19 13:04:28.568 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: type:EVENT
2016-06-19 13:04:28.569 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: eventNr:1
2016-06-19 13:04:28.570 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: value:End
2016-06-19 13:04:28.570 [TRACE] [.c.i.CalDavBindingProviderImpl] - found values: calendar=[muell], type=EVENT, eventNr=1, value=End
2016-06-19 13:04:28.571 [DEBUG] [.c.i.CalDavBindingProviderImpl] - adding item: Cal_Event1_End
2016-06-19 13:04:28.571 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config: calendar:muell type:EVENT eventNr:1 value:NAME
2016-06-19 13:04:28.572 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: calendar:muell
2016-06-19 13:04:28.573 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: type:EVENT
2016-06-19 13:04:28.573 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: eventNr:1
2016-06-19 13:04:28.574 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: value:NAME
2016-06-19 13:04:28.575 [TRACE] [.c.i.CalDavBindingProviderImpl] - found values: calendar=[muell], type=EVENT, eventNr=1, value=NAME
2016-06-19 13:04:28.575 [DEBUG] [.c.i.CalDavBindingProviderImpl] - adding item: Cal_Event1_Name
2016-06-19 13:04:28.576 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config: calendar:haeusele type:EVENT eventNr:1 value:NAME
2016-06-19 13:04:28.577 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: calendar:haeusele
2016-06-19 13:04:28.577 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: type:EVENT
2016-06-19 13:04:28.578 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: eventNr:1
2016-06-19 13:04:28.579 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: value:NAME
2016-06-19 13:04:28.580 [TRACE] [.c.i.CalDavBindingProviderImpl] - found values: calendar=[haeusele], type=EVENT, eventNr=1, value=NAME
2016-06-19 13:04:28.580 [DEBUG] [.c.i.CalDavBindingProviderImpl] - adding item: Cal_Event2_Name
2016-06-19 13:04:28.581 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config: calendar:gmail type:EVENT eventNr:1 value:NAME
2016-06-19 13:04:28.581 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: calendar:gmail
2016-06-19 13:04:28.582 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: type:EVENT
2016-06-19 13:04:28.583 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: eventNr:1
2016-06-19 13:04:28.583 [TRACE] [.c.i.CalDavBindingProviderImpl] - handling config part: value:NAME
2016-06-19 13:04:28.584 [TRACE] [.c.i.CalDavBindingProviderImpl] - found values: calendar=[gmail], type=EVENT, eventNr=1, value=NAME
2016-06-19 13:04:28.585 [DEBUG] [.c.i.CalDavBindingProviderImpl] - adding item: Cal_Event3_Name
2016-06-19 13:04:28.739 [DEBUG] [o.o.b.c.internal.CalDavBinding] - setting CalDavLoader: true
2016-06-19 13:04:28.740 [DEBUG] [o.o.b.c.internal.CalDavBinding] - CalDavBinding (personal) activated
2016-06-19 13:04:30.130 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /services/habmin
2016-06-19 13:04:30.151 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.104+02:00, to=2016-06-19T13:04:30.104+02:00, sort=null]
2016-06-19 13:04:30.152 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id haeusele not found
2016-06-19 13:04:30.153 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id muell not found
2016-06-19 13:04:30.153 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id gmail not found
2016-06-19 13:04:30.154 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.104+02:00, to=2016-06-19T13:04:30.104+02:00, sort=null] with 0 entries
2016-06-19 13:04:30.156 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.156+02:00, to=null, sort=null]
2016-06-19 13:04:30.157 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id haeusele not found
2016-06-19 13:04:30.157 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id muell not found
2016-06-19 13:04:30.157 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id gmail not found
2016-06-19 13:04:30.158 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.156+02:00, to=null, sort=null] with 0 entries
2016-06-19 13:04:30.159 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.159+02:00, to=null, sort=null]
2016-06-19 13:04:30.160 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id haeusele not found
2016-06-19 13:04:30.160 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id muell not found
2016-06-19 13:04:30.161 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id gmail not found
2016-06-19 13:04:30.161 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.159+02:00, to=null, sort=null] with 0 entries
2016-06-19 13:04:30.162 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.162+02:00, to=null, sort=null]
2016-06-19 13:04:30.163 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id haeusele not found
2016-06-19 13:04:30.163 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id muell not found
2016-06-19 13:04:30.164 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id gmail not found
2016-06-19 13:04:30.165 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[haeusele, muell, gmail], from=2016-06-19T13:04:30.162+02:00, to=null, sort=null] with 0 entries
2016-06-19 13:04:30.165 [DEBUG] [o.o.b.c.internal.CalDavBinding] - loading configuration…
2016-06-19 13:04:30.166 [DEBUG] [o.o.b.c.internal.CalDavBinding] - loading configuration done
2016-06-19 13:04:30.167 [TRACE] [o.o.b.c.internal.CalDavBinding] - reloading events
2016-06-19 13:04:30.168 [DEBUG] [o.o.b.c.internal.CalDavBinding] - calendar reloaded: haeusele
2016-06-19 13:04:30.169 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[muell], from=2016-06-19T13:04:30.168+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.169 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id muell not found
2016-06-19 13:04:30.171 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[muell], from=2016-06-19T13:04:30.168+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.172 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_Start, setting to UNDEF
2016-06-19 13:04:30.178 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[gmail], from=2016-06-19T13:04:30.177+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.179 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id gmail not found
2016-06-19 13:04:30.179 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[gmail], from=2016-06-19T13:04:30.177+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.180 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event3_Name, setting to UNDEF
2016-06-19 13:04:30.181 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_End, setting to UNDEF
2016-06-19 13:04:30.181 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_Name, setting to UNDEF
2016-06-19 13:04:30.182 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[haeusele], from=2016-06-19T13:04:30.182+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.183 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id haeusele not found
2016-06-19 13:04:30.184 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[haeusele], from=2016-06-19T13:04:30.182+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.184 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event2_Name, setting to UNDEF
2016-06-19 13:04:30.185 [DEBUG] [o.o.b.c.internal.CalDavBinding] - calendar reloaded: muell
2016-06-19 13:04:30.185 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[muell], from=2016-06-19T13:04:30.185+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.186 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id muell not found
2016-06-19 13:04:30.187 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[muell], from=2016-06-19T13:04:30.185+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.187 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_Start, setting to UNDEF
2016-06-19 13:04:30.188 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[gmail], from=2016-06-19T13:04:30.188+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.189 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id gmail not found
2016-06-19 13:04:30.189 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[gmail], from=2016-06-19T13:04:30.188+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.190 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event3_Name, setting to UNDEF
2016-06-19 13:04:30.191 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_End, setting to UNDEF
2016-06-19 13:04:30.191 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_Name, setting to UNDEF
2016-06-19 13:04:30.192 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[haeusele], from=2016-06-19T13:04:30.192+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.193 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id haeusele not found
2016-06-19 13:04:30.193 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[haeusele], from=2016-06-19T13:04:30.192+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.194 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event2_Name, setting to UNDEF
2016-06-19 13:04:30.195 [DEBUG] [o.o.b.c.internal.CalDavBinding] - calendar reloaded: gmail
2016-06-19 13:04:30.196 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[muell], from=2016-06-19T13:04:30.195+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.196 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id muell not found
2016-06-19 13:04:30.197 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[muell], from=2016-06-19T13:04:30.195+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.197 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_Start, setting to UNDEF
2016-06-19 13:04:30.198 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[gmail], from=2016-06-19T13:04:30.198+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.199 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id gmail not found
2016-06-19 13:04:30.200 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[gmail], from=2016-06-19T13:04:30.198+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.200 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event3_Name, setting to UNDEF
2016-06-19 13:04:30.201 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_End, setting to UNDEF
2016-06-19 13:04:30.201 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event1_Name, setting to UNDEF
2016-06-19 13:04:30.202 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[haeusele], from=2016-06-19T13:04:30.202+02:00, to=null, sort=ASCENDING]
2016-06-19 13:04:30.203 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - calendar id haeusele not found
2016-06-19 13:04:30.204 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[haeusele], from=2016-06-19T13:04:30.202+02:00, to=null, sort=ASCENDING] with 0 entries
2016-06-19 13:04:30.205 [DEBUG] [o.o.b.c.internal.CalDavBinding] - no event found for Cal_Event2_Name, setting to UNDEF
There is one row which says:
Why should be the “from” and “to” values are identical?
Thanks!
