febz11
(Erkan Balci)
June 5, 2017, 5:04pm
1
In case you need a change on the UI icons, you can try the icons created for Fibaro HC2 by the users.
https://forum.fibaro.com/index.php?/topic/11927-icon-for-the-hc2/&
Bonjour à tous, je ne suis certainement pas le seul à déplorer la qualité douteuse et la manque de diversité de certains icons (les zones) de notre interface préférée. De par mes connaissances très, très limitées en domotique z-wave (je suis un...
Please note that you have to sign-up for these forums. The icons are really high-class and 3D, but be aware that they are only PNG format, no SVGs. Like:
Can PNG icons be used, I’m only able to use SVG icons.
febz11
(Erkan Balci)
June 5, 2017, 5:16pm
3
Sure,
in Paper UI, go to Configuration, Services, UI, under Basic UI or Classic UI configuration button, you can change Icon Format from Vector to Bitmap.
wow, cool not known before, thanks a lot
