I’ve added a new device and requested review: item 881.
When I created the device and uploaded the XML, the first time it threw an error (I think it was a SQL error, bad Reeves, I should have copied it). I edited the XML to remove the neighbor nodes and submitted again and it succeeded (but complained the device ID already exists).
I’ve attached the XML file with node neighbors still in if you’d like to see if it repros. If you’d like me to try to reproduce the error I could edit the XML, changing the thing ID to something random (I don’t want to pollute the db without your direction ).
network_f1f3c5ef__node_42.xml (7.5 KB)
Cheers,
Reeves
