I use Docker commands directly to upgrade (well, I use Ansible to bring up the containers) so maybe there is something going on with that difference.
There have been some recent changes to automatically detect and build the correct architecture so we don’t have to specify that in the label anymore. Maybe something there went wrong.
Just throw away the existing container and create a new one when upgrading.
As long as you map your data directories/volumes in the new container it should work!
You can open up the tar files and have a look. I just did a quick table of contents of the most recent backup I have (from this morning) and it looks like it is everything in userdata.
How big is your userdata folder (minus the backups folder of course, we don’t need recursive backups)?
On my system the backups are all in the half gig range which tracks with the overall size of the userdata folder.
rich@argus:/o/o/u/backup (master) ✗ ls -lh
total 7.1G
-rw-rw-r-- 1 openhab openhab 404M May 7 2018 userdata-2018-05-07T13-28-13.tar
-rw-rw-r-- 1 openhab openhab 430M May 9 2018 userdata-2018-05-09T11-03-12.tar
-rw-rw-r-- 1 openhab openhab 437M May 30 2018 userdata-2018-05-30T14-08-32.tar
-rw-rw-r-- 1 openhab openhab 475M Aug 15 15:31 userdata-2018-08-15T15-31-41.tar
-rw-rw-r-- 1 openhab openhab 479M Sep 14 14:48 userdata-2018-09-14T14-47-35.tar
-rw-rw-r-- 1 openhab openhab 485M Oct 4 12:08 userdata-2018-10-04T12-08-12.tar
-rw-rw-r-- 1 openhab openhab 483M Oct 24 16:04 userdata-2018-10-24T16-04-25.tar
-rw-rw-r-- 1 openhab openhab 489M Oct 30 11:49 userdata-2018-10-30T11-49-20.tar
-rw-rw-r-- 1 openhab openhab 514M Nov 13 11:24 userdata-2018-11-13T11-24-49.tar
-rw-rw-r-- 1 openhab openhab 519M Nov 14 14:42 userdata-2018-11-14T14-42-22.tar
-rw-rw-r-- 1 openhab openhab 521M Nov 23 09:27 userdata-2018-11-23T09-26-40.tar
-rw-rw-r-- 1 openhab openhab 518M Dec 17 13:38 userdata-2018-12-17T13-37-50.tar
-rw-rw-r-- 1 openhab openhab 361M Jan 14 10:28 userdata-2019-01-14T10-28-11.tar
-rw-rw-r-- 1 openhab openhab 551M Jan 14 10:30 userdata-2019-01-14T10-29-02.tar
-rw-rw-r-- 1 openhab openhab 531M Jan 15 08:14 userdata-2019-01-15T08-14-21.tar
And I just realized that I don’t have this folder in my .gitignore. Off to git to clean this up.
+ mkdir /openhab/userdata/backup
+ tar --exclude=/openhab/userdata/backup -c -f /openhab/userdata/backup/userdata-2019-01-16T09-55-47.tar /openhab/userdata
tar: Removing leading `/' from member names
the issue might be, because I put the volume on a folder which is managed by glusterfs distribute FS
when I start tar in the shell, I get the same warnings, though tar goes on till finished.
going to play around with the the Dockerfile and find out whats going on.
