Hi all,
My rules were working perfectly before, I had my scenes defined so that i can turn lights on and off depending on the scene. I had presence detection working to calculate if I am home and select a scene on the result. Also I have a PIR sensor in my garage which turns on a light if movement is detected but none of this works now.
Nothing has changed except i moved the following from ‘Group Demo’ on the sitemap to the main sitemap screen in its own frame. (since i have reverted back to the original sitemap and still have issues)
Switch item=Scene_General label="Scene" mappings=[0=None, 1=TV, 2=Dinner, 3=Bed, 4=Off]
When ever the scene is changed, presence tries to detect or the garage PIR senses movement i get the following showing in the openhab.log
2016-02-13 18:44:40.823 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Activate Scene TV' java.lang.NullPointerException: null at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:107) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:112) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:150) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getParamTypes(JavaReflectAccess.java:144) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getMethod(JavaReflectAccess.java:76) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:759) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na] at sun.reflect.GeneratedMethodAccessor198.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na] at sun.reflect.GeneratedMethodAccessor194.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na] at sun.reflect.GeneratedMethodAccessor211.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na] at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na] at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na]
Bed Scene -
2016-02-13 18:44:44.434 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Activate Scene Bed' java.lang.NullPointerException: null at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:107) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:112) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:150) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getParamTypes(JavaReflectAccess.java:144) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getMethod(JavaReflectAccess.java:76) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:759) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na] at sun.reflect.GeneratedMethodAccessor198.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na] at sun.reflect.GeneratedMethodAccessor194.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na] at sun.reflect.GeneratedMethodAccessor211.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na] at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na] at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na]
PIR detected
2016-02-13 18:48:34.378 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'two car garage motion' java.lang.NullPointerException: null at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:107) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:112) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:150) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getParamTypes(JavaReflectAccess.java:144) ~[na:na] at org.eclipse.xtext.common.types.util.JavaReflectAccess.getMethod(JavaReflectAccess.java:76) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:759) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na] at sun.reflect.GeneratedMethodAccessor198.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na] at sun.reflect.GeneratedMethodAccessor194.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na] at sun.reflect.GeneratedMethodAccessor211.invoke(Unknown Source) ~[na:na] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0] at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0] at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na] at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na] at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na] at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na]
