Ciao Ricadelic
I haven’t yet got any result from the “official” openhab binding
no way to get it working
still good in seeing in the trace window that openhab logs in honeywell server, and receive answers correctly, with all details about my devices, but at openhab item level, no activity at all
it seems something is not matching at item configuration level
It would be great if anybody could share his files .item and openhab.cfg to see if something is wrong
unfortunately I’m not so good to recompile the binding in java, and so I’m not able to debug it
I definitely agree with you, an external python routine could be an effective walkaround
I was already looking around on exec binding, but the solution you linked is similar and ready to use
as a programmer… it is a defeat…
I’ll try to implement the walkaround in python in the next days
All i did was to copy the items and link them to a group. Then in the sitemap i displayed the group.
The only thing i cannot get working is the settime variable. Did you get all the other vars working?
in my implementation I can’t see any variable displayed in the interface
neither any variable moves in the event log
the binding code gets login with Honeywell server, and I see all the data received with all details of my devices
also I tried to reinstall openhab on a scratch raspberry, so I feel I can exclude openhab installation
I have some doubts for the item configuration string, but I played several combination of quotes/names/capital letters… but no way to run
can you share your configuration for items and what you set in openhab.cfg (masking your account of course)?
Does anyone know what the status is of this binding? It’s been more than a year since the original version and afaik no updates have been made since.
I think it could be converted into an Openhab2 binding to make configuration a lot easier (since the JSON response contains all info needed to make Things)
The one thing I’m really missing is to be able to set quick actions; viewing temps is a nice feature, but I’m looking to integrate it to at the level where IFTTT is. The IFTTT interface is a nice idea, but it way to slow to be of value to me… Does anyone know how setting quick actions works or how to reverse engineer it from the app?
Lastly, I’m happy to pick up some of the coding and get thing moving =)
Well I’m on the cusp of moving to Openhab2 so I’m about to start moving this and my other bindings across to OH2. You are right the xml would make config really easy in OH2.
I never really used quick actions hence they weren’t implemented and even more setting temperature is tough without a proper scheduling ability in Openhab.
Hi Neil, thanks for the swift reply! I just made the transfer to OH2 myself and I’ve got to say I’m pretty impressed with the whole Things concept.
I see where you are coming from time wise; I’ve got a little one of the age of yours as well, I see, and a second on the way
I was so free as to create an issue for the binding here: https://github.com/openhab/openhab2-addons/issues/2268. What do you say we’ll make it a joint effort? I already spent some time diving into the OH2 bindings and have a plan to start the implementation. Let me know if you’re interested and I’ll share with you my train of thought.
I’ve been looking to learn about the “Thing” coding have you come across is this mythical yahooweather binding that is in all the examples? I can’t find it anywhere!
Yeah, our first is just about doing that as well Magical times!
I created a fork as well, but haven’t committed anything yet. I’ll let you know when I have, probably somewhere today.
I stumbled upon this set of documentation: Archived Projects | The Eclipse Foundation (maybe you already found it) and it’s serving me quite well! I already have implemented a Bridge Thing along with the username, password and applicationId settings. It’s showing up OH2 as a binding and as a thing: awesome!
I’ve been basing my work on the org.openhab.binding.toon and org.eclipse.smarthome.binding.yahooweather bindings. The first because it very much resembles the Evohome system (https://www.eneco.nl/toon-thermostaat/ it’s a dutch product, sorry ;-))
I was just about to port your API classes where a question arose: you used the org.codehaus.jackson package for json manipulation I think. Is there a particular reason to use that library? Or can we convert to the GSON package as @Kai would like to see (openHAB JSON library (not JSONPATH) - #4 by steve1)?
Edit: reading the previously mentioned post I see that for HTTP the “Jetty HTTP client library” is preferred so I propose changing to that as well
I’ve managed to find the yahooweather binding code.
No reason not to use the standard HTTP and JSON library - I can’t remember why I chose one over the other but what we need it for isn’t exactly rocket science so I think either will work.
I think you have to use the openhab namespace otherwise it causes all sorts of problems. Go with the lowest barrier to entry and at a later date it can always be changed and ported if it is needed.
I had a quick look through the first commit - you will need to rename your sample channel at some point. I spent my lunchtime getting my laptop setup to code for OH2. That being said I might wait before doing too much so we don’t end up both doing the same work.
Indeed, I need to. I left it there because it doesn’t allow me to leave the file like that without any channels defined. Channels, however, are not yet on my todo list in the near future
I pushed all my work up and probably won’t have time the upcoming days to work on it so feel free to fiddle around with it.
Shall we use this topic to align our work? Or shall we do that in the github issue?
Yesterday evening I looked at the python code you sent a link to earlier. It looks like that one is using OAUTH and is able to get more data via a different set of endpoints I cannot access with just the sessionID header. I think I want to implement that one instead, since that gives me access to the quick actions.
Could you check if that python code works for you as well? I don’t know if it is region based, for me in the Netherlands it works at least.
I think my main focus would be the gateway channels and setting quick actions. That leaves open the Things connected to the gateway i.e. the radiator controls. That and Thing discovery might be something you could pick up if that’s okay?
Jasper and Neil,
very nice to hear you are working on this binding
my problems with evohome legacy binding are still pending, but I haven’t enoth competence to develop any code by myself
so great you are working for the community, thank you a lot!
should you need any help for testing, I’m here
Ciao
Alberto
I’ve ported your code locally and login works. Going to see if I can get some data now im logged in. The work split certainly works as the valves are more interesting to me.
I was able to get a working login with the new API. Unfortunately that means that the old API as was used in your OH1 binding can no longer be used. I’ll push my changes in a moment, please check if the login still works for you then.
