I have install openhabian 1.7 with openhab branch 2.5.12
Restore with backup from 2…5.10
Moving system files in userdata to temporary folder
Deleting old userdata folder…
rm: cannot remove ‘/var/lib/openhab2/persistence’: Device or resource busy
Restoring system files in userdata…
Deleting old conf folder…
Restoring openHAB with backup configuration…
Deleting temporary files…
Backup successfully restored!
All is work fine. After this i have this errors in the log.
2021-12-19 20:58:41.340 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-package-standard’: No matching features for openhab-package-standard/0
2021-12-19 20:58:41.929 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-hue, openhab-binding-exec, openhab-binding-deconz, openhab-misc-openhabcloud, openhab-ui-habot, openhab-binding-amazonechocontrol, openhab-ui-habpanel, openhab-binding-enigma2, openhab-transformation-map, openhab-ui-habmin, openhab-transformation-exec, openhab-ui-paper, openhab-ui-homebuilder, openhab-binding-milight, openhab-binding-amazondashbutton, openhab-binding-tplinksmarthome, openhab-transformation-regex, openhab-binding-weatherunderground, openhab-binding-mystrom, openhab-binding-tankerkoenig, openhab-ui-basic, openhab-binding-ntp, openhab-misc-homekit, openhab-binding-openweathermap, openhab-binding-gardena, openhab-binding-astro’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-habmin; type=karaf.feature; version="[2.5.10,2.5.10]"; filter:="(&(osgi.identity=openhab-ui-habmin)(type=karaf.feature)(version>=2.5.10)(version<=2.5.10))"
2021-12-19 20:58:56.383 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
Anybody a hint or solution?
Regards
Maik
