I just went to inbox, hit the plus and went through the zwave menus. Any help would be greatly appreciated. Also if I can just manually edit a file and set it to keep me going that is a good temp fix.
I can confirm this is a problem with a new build using Maven snapshot #427 as I did the same thing last night. Try installing HABmin and setting the port on the controller there. This worked for me!
