I’m trying to move from OpenHAB 1.8 to OpenHAB 2 on a raspberry pi 3 with the latest image but I’m getting an error when running the apt-get install. I followed the steps under the linux install instructions on the OpenHAB 2 documentation and I updated the repositories and the public key without any issues. When I run the commend “sudo apt-get install openhab2-offline” though I get the following after download:
dpkg: error processing archive /var/cache/apt/archives/openhab2-offline_2.0.0-20161017033125_all.deb (–unpack):
subprocess new pre-installation script returned error exit status 1
E: Sub-process /usr/bin/dpkg returned an error code (1)
Am I doing something wrong or is there an issue with the archive server at the moment?
@Duncan_Pullen, @mladams922, If you experience further problems you may want to make sure that the openhab user/group owns the folder, since we were the ones to create it not openhab:
I did that and it resolved some of the startup issues I was having as well. Now it seems to be running ok with the exception of a few things I need to troubleshoot.
