The SD Card was created from the Raspberry Pi Imager
The latest version was chosen and I can see that its 13.3 (aka Trixie)
The issue is the openhabian.conf file was not uncompressed and so its a “corrupted” file
I can now login through ssh with the openhabian user and default password but there is no openHAB installed and even the login just shows a normal debian login
My question since the system has already booted - can i just re-run the first-boot.bash (with the correct openhabian.conf ) and the config will run - or is it better to reimage again completely
in this case I can - what happened is the user put the openhabian.conf.gz file and renamed it to openhabian.conf so the system could never read the file
I uncompressed it now (and can read it) if I run the first-boot.bash again would it work (correctly)
Long term i’m still thinking that the reimage is the best but that delays things for a week for me (#OnlyMeBeingImpatient )
