Did you delete the Thing and rediscover it? That’s needed to get the latest update. (This does not mean exclude/include, it means only deleting the thing and rediscovering.)
The other possibility is that the database update for this device missed the cutoff for 2.5.4 and will be in 2.5.5 when it comes out.
OH 2.5.x is planned to be released about once a month.
I think @chris said he built a snapshot of the binding after 2.5.4. You could try to install the latest snapshot using the script. (sound familiar?)
I’ll give that script another try. Might have gotten tripped up because it doesn’t show anything when I type the password so I tried to delete what I typed and then start again but maybe I got that wrong.
On another note, any chance the second xml file I sent for the dimmer switch also made it in to the latest zwave snapshot?
Still not having any luck getting the script to work. Any thoughts? It did not ask me for a password so that can’t be the problem. Attached is the sequence of screenshots from the process start to finish.screen images.pdf (315.5 KB)
openhab.log (947.1 KB) frankly I don’t know what I’m doing. It says I should run it as the same account as openhab so I was concerned running it as root was the problem so I google’d how to run commands as another user which led me to the command I posted. As for the log, I attached it. The script was run at 10:04 and ended at 10:07. Appreciate the help.
