I am in the process of adding support for Revolt Energy Monitors to the binding. In order to do this, I had to change code for the init commands and also made changes that might affect other sensors. It would be nice if some of you can install the new version and report back if everything still works before I create a pull request.
Thanks mate.
Nothing is blocking port 81. Iāve done port scans and the port just isnt open.
I am wondering if I should be changing the proxy settings in the gateway with the advanced tool - redirecting the gateway traffic from box.weatherdirect.com to the openhab server maybe?
This seems to be a completely different device than the LaCrosse Gateway that is supported by this binding, which is a self-soldered solution with a custom firmware (https://wiki.fhem.de/wiki/LaCrosseGateway_V1.x).
So most likely you canāt use the Jeelink Binding to connect your GW1000U to OpenHab at all.
after my upgrade to Openhabian 2.5 stable I had to re-create the Jeelink binding and re-add the āLaCrosseGateway am USB Portā.
In the logs I saw the following error message this time. Not sure if this is critical (everything seems to still work fine after adding the Jeelink sensors thereafter), however I wanted to pass on the observation I have when adding the gateway, in case this is something related to V2.5 worth looking at:
2020-01-01 23:44:35.700 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener āorg.eclipse.smarthome.core.thing.internal.ChannelItemProvider$1@12a5a4eā about the āUPDATEDā event: Error creating a dimension Class instance for name āPercentā.
java.lang.IllegalArgumentException: Error creating a dimension Class instance for name āPercentā.
at org.eclipse.smarthome.core.types.util.UnitUtils.parseDimension(UnitUtils.java:89) ~[bundleFile:?]
at org.eclipse.smarthome.core.library.items.NumberItem.<init>(NumberItem.java:75) ~[bundleFile:?]
at org.eclipse.smarthome.core.library.CoreItemFactory.createItem(CoreItemFactory.java:81) ~[bundleFile:?]
at org.eclipse.smarthome.core.library.CoreItemFactory.createItem(CoreItemFactory.java:1) ~[bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.ChannelItemProvider.createItemForLink(ChannelItemProvider.java:241) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelItemProvider.access$2(ChannelItemProvider.java:227) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelItemProvider$1.added(ChannelItemProvider.java:316) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelItemProvider$1.updated(ChannelItemProvider.java:336) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelItemProvider$1.updated(ChannelItemProvider.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:366) [bundleFile:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.notifyListenersAboutUpdatedElement(AbstractRegistry.java:387) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:143) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:1) [bundleFile:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:291) [bundleFile:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) [bundleFile:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:62) [bundleFile:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:87) [bundleFile:?]
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.update(AbstractManagedProvider.java:119) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1$1.run(ThingManagerImpl.java:261) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1$1.run(ThingManagerImpl.java:1) [bundleFile:?]
at java.security.AccessController.doPrivileged(Native Method) [?:1.8.0_222]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1.thingUpdated(ThingManagerImpl.java:249) [bundleFile:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateConfiguration(BaseThingHandler.java:441) [bundleFile:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.handleConfigurationUpdate(BaseThingHandler.java:105) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:93) [bundleFile:?]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:438) [bundleFile:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [bundleFile:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [bundleFile:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [bundleFile:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Please excuse should this be a āfalse alarmā.
Thanks for your great work in keeping Jeelink running smoothly.
Thanks for the information. I have also upgraded to 2.5.0 and did not have any problems. So it does not seem to be a general problem. Anybody else having problems with the jeelink binding after upgrading to 2.5?
many thanks for the binding. I have a question regarding LaCrosse Gateway. I use some of them with a directly connected Temp/Hum Sensor. These sensors are not visible within the binding and can not configured manually. So I think this option is not supported by the binding until now. Is it possible to add the support for this setup?
Adding support is possible as long as the LGW writes the values of the connected sensors to the serial/TCP port as it does for the other sensors. Set debug level trace using the openhab console and post a relevant part of rthe openhab logv containing ouput for the directly connected sensors. I can then add support when I find the time.
Now i only need to find a description of the format of the internal sensors. I will have to check the LGW source code and keep you posted on the progress.
I am wondering why the LGW reports values for two different connected sensors. Reading the LGE docs, it states:
Wenn ein BME280 vorhanden ist, wird dieser verwendet und sonst nichts, da man dann bereits Temperatur, Feuchte und Druck hat.
Your first sensor (id71) has temperature, humidity and pressure, so should be a BME280. According to the docs, all other sensors should be ignored. Your second sensor (id75) has temperature and humidity, so should be a DHT22, correct? I would like to understand what is happening so the binding supports everything correctly.
You are right. In my setup the 71 has a BME280 connected, the 75 a DHT22. So far documented, a BMP180 or LM75 sensors also possible, but I think with the BME280 the max. supported values available.
You can try this jar file, which should support internal LGW sensors. If it works I can create a pull request to have it officially added. Remove the currently installed add-on and copy the jar to the add-ons directory.
I have created a pull request: https://github.com/openhab/openhab-addons/pull/7153. I have to make some changed to get it merged. After that it will take one or two days for it to show up in the official distribution.
