I think the errors you are seeing are harmless. They’re just the binding saying that it doesn’t implement the REFRESH command (when the thermostat is online, the values are fetched from the thermostat every so often, based on the refresh interval setting on the thermostat thing). Still, I think it wouldn’t be too difficult to add support for REFRESH, if only to make that error go away.
When you say, malform the items, what exactly do you mean? Sending invalid temperature values, for instance? And at that point, if a value on the thermostat changes, you no longer see that change reflected in OpenHAB (after the refresh timeout, at least)?
I will take a look and try to see if something needs to be adjusted to get the dependency pulled in automatically. I’m not using the Sonos binding, but it’s possible one of the bindings I am using is doing that for me.
So, I think that there’s a problem with PaperUI, as I saw a similar problem. The reason I think it’s not directly related to the binding is that the error is coming during processing of the POST message, which happens before the value is sent to the binding. I was going to do a little digging to try to find the source of the problem, but haven’t had time yet.
I think the end goal is for this to be part of the openhab2-addons project; there are a few more improvements I’d like to see before we submit it.
Is the “system state” field mapping correctly for you in PaperUI? It was working correctly at one point, but now I just get the integer value, such as 0 instead of “Idle”… I want to make sure it’s not just my install being messed up before I spend a lot of time trying to find the source of the problem.
First off, I think my initial issue was refreshing BasicUI before OH had a chance to reload. I thought I was introducing errors into my items file but that wasn’t the case. I just had to give OH a chance to reload the file after I made my edits. No issue there. (I thought the refresh issue was related, it sounds like it’s not.)
I am having trouble with state and mode. Mode is always ‘Off’ and state is always null. I thought I had issues with my item definition but maybe not? So far temp and humidity are fine, I haven’t moved beyond mode and state yet.
Can I trouble you to post examples of the item and sitemap entries for each item? I think that would help me get going and may help in troubleshooting as well.
Thanks again for your work on this, it is appreciated!
It very well could be a problem with paperui. I have taken a screen shots to help illustrate the issue. This screen shot is just after I click on green check mark to set the new temperature (in paperui). I thought I should also mention that when I change the temperature from paperui, the change is never made on the thermostat. I will try connecting the items to habpanel and see if I can get it to change the temperature on the thermostat from there.
Yes, I get the same sort of result in PaperUI (a number 0 when the system is idle, etc). This used to work, and I’m pretty sure the code on the binding end hasn’t changed in any meaningful way, so I’m inclined to think the problem is in the UI (as is the strange behavior when changing values that involve units conversion). I will dig a little deeper when I have a little free time over the next week or so.
Most all of my OpenHAB devices are “managed” by OpenHAB… which I am learning means discovered and configured in PaperUI, so I don’t really have much in my .items files. I’ve set up all of the bindings I’ve written to work that way, as I was under the impression that was “the way forward”, though my experience is that that path isn’t exactly smooth yet.
My thermostat related portions of the sitemap look a little like this (where Downstairs is the name of one of my thermostats):
It might also be informative to see if you can change values using the OpenHAB console… something like this:
smarthome:send venstarthermostat_colorTouchThermostat_98f17068b1b5_heatingSetpoint XX
where XX is the temperature you want to set the thermostat to… this should bypass any problems in the UI and REST interfaces and speak directly to the thermostat (I think).
Progress! When I looked closely at the venstar channels in PaperUI I noticed they were all ‘Number’, even the mode and state. When I changed my item data types for those two to Number my sitemap started showing the correct (text) values. (Idle and Cool)
Number HVACState "State [%s]" {channel="venstarthermostat:colorTouchThermostat:00aefabb372c:systemState"}
Number HVACMode "Mode [%s]" {channel="venstarthermostat:colorTouchThermostat:00aefabb372c:systemMode"}
Frame label="Climate" {
Text item=HVACTemperature icon="temperature"
Text item=HVACHumidity icon="water"
Text item=HVACState
Text item=HVACMode
I assumed the mode and state would be text values so I originally defined them as strings in my items file.
For the PaperUI control my mode now shows correctly but my state is now a number, same as you guys. I am able to change the mode from PaperUI and have it update the thermostat.
I uploaded a new version of the binding, it should fix the System Mode and System State mappings. Because the fix involved changing the data type of these channels, you’ll need to remove your things and re-add them once you’ve upgraded the binding version. Once you’ve done that, you should see that the system state and mode channels are now of type “String” rather than “Number”.
I don’t have a fix for the problem with changing values when using SI units; I am still pretty sure that the problem is outside the binding. It might be helpful for someone to open a bug report or a new topic here to see if the OpenHAB wizards are aware of the problem.
Hello all. I’m new to ISY and OpenHAB, but have made good progress in getting things setup, using Harmony(lighting) and iRule(lighting, thermostat). I have started creating dashboards with OpenHAB and have made progress but I am having issues controlling an Insteon 2414 thermostat. I have the Binding installed, and online, solid green, and I am able to set the temperature setpoints and read the temp/humidity and states, but I have not figured out how to set Mode(Off,Heat,Cool,Auto, Auto Prog) and Fan Mode(On, Auto). I can read their current state, but cannot change them. I have tried and tried all sorts of combinations and iterations without luck. I have looked at a number of forums for examples and guidance, but just can’t seem to crack the code Can anyone provide me with guidance and point me in the right direction. Other than these two open items I have no issues.
Apologies if this not the right forum for this post. I also requested assistance on the UD forum.
I’m trying to get this binding to work, but I’m getting the following error (I xx’d out the USN and ip address):
2019-06-20 10:27:17.398 [TRACE] [org.openhab.binding.venstarthermostat.internal.discovery.VenstarThermostatDiscoveryService] - key: man value: ssdp:discover.
2019-06-20 10:27:17.399 [TRACE] [org.openhab.binding.venstarthermostat.internal.discovery.VenstarThermostatDiscoveryService] - key: st value: colortouch:ecp.
2019-06-20 10:27:17.407 [TRACE] [org.openhab.binding.venstarthermostat.internal.discovery.VenstarThermostatDiscoveryService] - Found thermostat, name: null uuid: null url: null
2019-06-20 10:27:17.408 [TRACE] [org.openhab.binding.venstarthermostat.internal.discovery.VenstarThermostatDiscoveryService] - Bad Format from thermostat
2019-06-20 10:27:17.497 [TRACE] [org.openhab.binding.venstarthermostat.internal.discovery.VenstarThermostatDiscoveryService] - Match: HTTP/1.1 200 OK
Cache-Control: max-age=300
ST: colortouch:ecp
USN: ecp:98:f1:70:xx:xx:xx:name:Breezeway:type:residential
(this if followed by a blank line and a long string of nulls in the log file)
Any ideas? Or is there somewhere I can access the source code to debug?
Hi, I’m sorry for not replying sooner; for some reason I didn’t see that you’d posted to this thread. I’ve got a newer version of the software that might solve your problems. I’ll post that info in another message as a reply to another question on this thread.
What model thermostat and firmware version are you running?
I’ve got a newer version that I’ve been working on as part of an attempt to get this binding added to the openhab core. You might want to try that out:
That sounds familiar… I think the format of that field changed somewhere along the way; you might try upgrading the firmware to see if that resolves the problem (we’ve also noticed that there are stability improvements with newer firmwares…
I’ll also take a look and see if the binding can be made to recognize either format.
OK, that makes sense. Give me a couple days and I’ll see if I can switch things to support both. Might take a round or two of testing, but I think we can get both versions of the firmware supported.
