Perfect - I will just try it out
Thanks a lot!
Little OFF topic, but some of you know a service similar to Tankerkoenig which works all over Europe?
I donāt think so. There might be something similar in other countries but IMHO no system for neither EU nor Europe.
Hello together,
there are some points what i dont understand and have to less information. At this point my binding stay offline.
Now i try to understand what you are doing with certificate. First, iām not really sure if i download the right cert. Otherwise i get an error with passwordā¦
Can some body give me more details at this points please:
- Check which certificate authory has validated the certificate
- In your browser, go to https://creativecommons.tankerkoenig.de/
- Check which certificate authority has validated the certificate
- Export the certificate of the certificate authority
Thank you.
Welcopme to the openHAB forum
Please state what you have done already!
Did you create the things via PaperUI or via files?
Did you create only the webservice or gas-stations as well? (Without any gas-station the webservice will stay OFFLINE!)
On what system did you install openHAB? Iām using a RaspPI with openhabian and did see the certificate problems.
And if the problem is really with the certificate @Andreh_T, could you step in?
Iām using RaspPi. I created all things and as well the gas stations. All IDās are valid, cause i use another script where this works perfect.
As i know that there is a cert error, but i didnāt have a clue with this points what i post beforeā¦
Where can i get the cert file? Iām using Firefox⦠I download something but its perm is that the same?
I copy that to my pi and execute keycommand after this i get request to insert password i use changeit but it doesnāt work. I got wrong password but i didnāt change itā¦
How and when did You install openHAB? Which version?
I would have expected that the certificate problem vanished on recent complete installs.
As you may have read in the older posts above I am not the expert in the certificate problem. I pinged the author of those lines in the docs.
Thanks for your help so i got it to work⦠I use this command and all went wellā¦
sudo keytool -import -keystore cacerts -alias LetsEncrypt -file /home/pi/ca.cert -storepass changeit
after reboot the things are all well.
Could you answer my previous questions?
If the problem is still noticeable on actual systems the docs might need an update.
Itās an rapi 3 with this Raspian version:
PRETTY_NAME=āRaspbian GNU/Linux 9 (stretch)ā
NAME=āRaspbian GNU/Linuxā
VERSION_ID=ā9ā
VERSION=ā9 (stretch)ā
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL=āhttp://www.raspbian.org/ā
SUPPORT_URL=āhttp://www.raspbian.org/RaspbianForumsā
BUG_REPORT_URL=āhttp://www.raspbian.org/RaspbianBugsā
JDK:
java version ā1.8.0_65ā
Java⢠SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot⢠Client VM (build 25.65-b01, mixed mode)
Use this way for installation at last Monday:
Thats my config. Hope that help out.
