This lock parameter could be a socket property that prevents the user from changing the state of the outlet item that is linked to the respective channel.
On the other hand… maybe we are going into too much detail and this feature is not really needed… Up to you.
By the way: Since OH2 Snapshot releases are now numbered 2.1.x, maybe you should update your mPower binding version number to 2.1.02
@magcode thanks a lot, your binding works great. I was looking for a Greenwave 6-node zwave power bar since some time for my network rack, but somehow it seems they canceled this product… Thanks to your binding I did not only find a perfect integration into openhab, but also a replacement product
Currently running org.openhab.binding.mpower 2.0.02.201701242116 on 3 systems (2 test and 1 prod) with openHAB2 (2.0.0 Stable, 2.1.0 Stable, 2.2.0 Snapshot #988)
Thanks @Dim for testing the binding on recent OH versions. Very much appreciated. Unfortunately I need to stop my contribution. I consider making the binding available on my github account.
For whoever wants to continue the great contribution of @magcode for this mPower binding:
Starting with openHAB 2.2 Snapshot #1002 (that included many ESH updates), I get the following warning in the log for this binding:
2017-08-04 22:36:08.350 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mPower.things'
2017-08-04 22:36:17.017 [WARN ] [.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
I think that it has to do with this part of the code: Line 26 (maybe I should have opened an issue on github)
No worries, I will fix this latest once I’m on OH2.2. Currently I’m migrating to OH2.1.
I just don’t have the time to make this binding an official part of OH.
first of all, thx again for the binding… Almost works like a charm. Only issue I have is the following minor one:
Due to a hardware defect I had to replace my power bar - The new one was autodiscovered as I remember and works fine. However I still have the old things in openhab and cant remove them. When I select those things in paper UI and “remove” them they are shown as “removing”, but never disappear. Furthermore openhab log keeps displaying the following lines every 20 second (no matter if I tried to remove the things or not):
How did you define them in the first place?
Using *.things and *.items files or via the PaperUI Simple Mode for Item Linking?
It seems that you used PaperUI, so you should have followed another sequence to clear your OH2 system from the old info.
First, you delete the links from the channels, then delete the Items, then delete the Things.
Since you removed the Thing first, you are left with orphan links and items in your system.
To remove those, you could use the openHAB console and:
smarthome:links list |grep -i mpower
This command will show you the links between the Items and the Channels of the Things.
You can delete the links with smarthome:links removeChannelLink <itemName> <thingUID>
Then, you can also delete the old Items with: smarthome:items remove <itemName>
Thanks - I did something very stupid and now my openhab doesnt start anymore, unfortunately I’m remote from home. I will check over the weekend, and provide feedback here.
thanks, this solved the issue with my orphaned things. I’m having an issue now that the replacement mpower device is not initializing anymore, but this seems to be another issue caused by some mistake I made as zwave and plugwise are not initializing correctly anymore as well. By chance I deleted my “runtime” folder and dont have a backup…
just as a note - i didnt create any things/items manually, just used autodiscover from paper UI… and I think i didnt even link the channels manually, this was done automatically.
Yes, the original repo is now closed.
The jar still works. I can provide a download link if you want.
Development has been frozen/stopped from @magcode
He made a big effort to get it merged into the distribution but it didn’t work out
Indeed. It is dead/down/discontinued. I was not able to fulfill the quality requirements of this project.
I suggest to use https://github.com/magcode/mpower-tools/tree/master/mqtt/client as a replacement. This is what I use for my 7 mpower devices at home now.
