I upgraded my config with the new onewire binding and used the following config files
onewire.things:
Bridge onewire:owserver:mybridge [ network-address="127.0.0.1" ]
Thing bms chBath2F [ id="26.23B32E010000", id1="28.CF971B030000", lightsensor=false, temperaturesensor="DS18B20", refresh=30 ]
{ Channels:
Type temperature-por-res : temperature [ resolution="11"]
Thing temperature chStudy [ id="28.984CDE030000", refresh=10 ]
{ Channels:
Type temperature-por : temperature
items
Number tmpStudy "Temp. Studeerkamer [%.1f °C]" <temperature> (Study,Temperature) { channel="knx:device:bridge:DEV203:Ch203F_ist",
channel="onewire:temperature:mybridge:chStudy:temperature" }
Number:Temperature tmpBathroom2F "Temp Badkamer [%.1f °C]" <temperature> (Bathroom2F,Temperature) { channel="onewire:bms:mybridge:chBath2F:temperature" }
Number humBathroom2F "Hum Badkamer [%.1f%%]" <humidity> (Bathroom2F,Humidity) { channel="onewire:bms:mybridge:chBath2F:humidity" }
In the paperUI the bms sensor shows online and gets updates, the temperature sensor gets stuck at initializing. If I disable and enable the temperature sensor, it comes back online and works.
The issue can be recreated by restarting openhab or by touching the thing file.
After a few hours both sensors do not respons anymore.
All worked fine for years with the onewire1 binding.
The software runs on debian, openhabian and with the latest milestone.
Anybody a hint?
BMS sensor responding, temperature sensor times out
14-jan-2019 18:59:11.720 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488751719, 2 childs
14-jan-2019 18:59:11.720 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:11.721 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:11.722 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 18:59:11.723 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType PRESENT, size 40, controlFlags 0x00000124, payload '26.23B32E010000'
14-jan-2019 18:59:11.726 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 0, size 32, controlFlags 0x00000124, payload '&#�.???A'
14-jan-2019 18:59:11.727 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - presence 26.23B32E010000 : ON
14-jan-2019 18:59:11.729 [TRACE] [g.onewire.internal.handler.MultisensorThingHandler] - refreshing analog onewire:bms:mybridge:chBath2F
14-jan-2019 18:59:11.730 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 18:59:11.731 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType READ, size 53, controlFlags 0x00000104, payload '/26.23B32E010000/temperature'
14-jan-2019 18:59:11.793 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 12, size 36, controlFlags 0x00000104, payload ' 14'
14-jan-2019 18:59:11.795 [TRACE] [e.smarthome.binding.onewire.internal.device.DS2438] - read temperature 14 °C from 26.23B32E010000
14-jan-2019 18:59:11.797 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 18:59:11.811 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType READ, size 50, controlFlags 0x00000104, payload '/26.23B32E010000/humidity'
14-jan-2019 18:59:11.953 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 12, size 36, controlFlags 0x00000104, payload ' 60.3236'
14-jan-2019 18:59:11.954 [TRACE] [e.smarthome.binding.onewire.internal.device.DS2438] - read humidity 60.3236 % from 26.23B32E010000
14-jan-2019 18:59:11.962 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 18:59:11.964 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType READ, size 45, controlFlags 0x00000104, payload '/26.23B32E010000/vis'
14-jan-2019 18:59:11.999 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 12, size 36, controlFlags 0x00000104, payload ' 0.0014646'
14-jan-2019 18:59:12.000 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 18:59:12.001 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType READ, size 45, controlFlags 0x00000104, payload '/26.23B32E010000/VDD'
14-jan-2019 18:59:12.002 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 12, size 36, controlFlags 0x00000104, payload ' 4.62'
14-jan-2019 18:59:12.003 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 18:59:12.003 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType READ, size 53, controlFlags 0x00000104, payload '/28.CF971B030000/temperature'
14-jan-2019 18:59:12.692 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 12, size 36, controlFlags 0x00000104, payload ' 14.75'
14-jan-2019 18:59:12.693 [TRACE] [.smarthome.binding.onewire.internal.device.DS18x20] - read temperature 14.75 °C from 28.CF971B030000
14-jan-2019 18:59:12.697 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:12.698 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:13.699 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488753698, 2 childs
14-jan-2019 18:59:13.699 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:13.700 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:13.700 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:13.700 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:14.702 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488754702, 2 childs
14-jan-2019 18:59:14.703 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:14.704 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:14.705 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:14.706 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:15.707 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488755707, 2 childs
14-jan-2019 18:59:15.708 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:15.708 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:15.708 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:15.709 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:16.710 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488756710, 2 childs
14-jan-2019 18:59:16.711 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:16.712 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:16.712 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:16.713 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:17.714 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488757714, 2 childs
14-jan-2019 18:59:17.715 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:17.715 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:17.716 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:17.717 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:18.718 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488758717, 2 childs
14-jan-2019 18:59:18.719 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:18.720 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:18.720 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:18.721 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:19.722 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488759722, 2 childs
14-jan-2019 18:59:19.722 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:19.722 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:19.723 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:19.723 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:20.724 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488760724, 2 childs
14-jan-2019 18:59:20.725 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:20.726 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:20.727 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:20.729 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:21.730 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488761729, 2 childs
14-jan-2019 18:59:21.730 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:21.732 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:21.732 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:21.733 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:22.734 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488762734, 2 childs
14-jan-2019 18:59:22.735 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:22.736 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:22.737 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:22.738 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:23.739 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488763739, 2 childs
14-jan-2019 18:59:23.740 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:23.741 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:23.742 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:23.743 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:24.745 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488764745, 2 childs
14-jan-2019 18:59:24.746 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:24.746 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:24.747 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:24.747 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:25.749 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488765748, 2 childs
14-jan-2019 18:59:25.749 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:25.750 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:25.751 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:25.751 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:26.752 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488766752, 2 childs
14-jan-2019 18:59:26.753 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:26.754 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:26.755 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:26.755 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:27.757 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488767757, 2 childs
14-jan-2019 18:59:27.757 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:27.758 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:27.759 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:27.759 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:28.760 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488768760, 2 childs
14-jan-2019 18:59:28.761 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:28.762 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:28.763 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:28.763 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:29.764 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488769764, 2 childs
14-jan-2019 18:59:29.767 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:29.769 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:29.771 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:29.775 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:30.777 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488770777, 2 childs
14-jan-2019 18:59:30.777 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:30.778 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:30.779 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:30.779 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:31.780 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488771780, 2 childs
14-jan-2019 18:59:31.781 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:31.782 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:31.782 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:31.783 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:32.784 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488772784, 2 childs
14-jan-2019 18:59:32.785 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:32.786 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:32.786 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:32.787 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:33.788 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488773787, 2 childs
14-jan-2019 18:59:33.789 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:33.789 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:33.790 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:33.790 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:34.791 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488774791, 2 childs
14-jan-2019 18:59:34.791 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:34.792 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:34.793 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:34.794 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:35.796 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488775795, 2 childs
14-jan-2019 18:59:35.796 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:35.797 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:35.798 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:35.798 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:36.799 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488776799, 2 childs
14-jan-2019 18:59:36.800 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:36.801 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:36.801 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:36.802 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:37.803 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488777803, 2 childs
14-jan-2019 18:59:37.804 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:37.805 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:37.805 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:37.806 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:38.807 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488778807, 2 childs
14-jan-2019 18:59:38.807 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:38.808 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:38.808 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:38.809 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:39.811 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488779811, 2 childs
14-jan-2019 18:59:39.811 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:39.812 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:39.813 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:39.813 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
14-jan-2019 18:59:40.814 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547488780814, 2 childs
14-jan-2019 18:59:40.815 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 18:59:40.816 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 18:59:40.816 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 18:59:40.817 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor not initialized, skipping refresh
Temperature sensor OK
14-jan-2019 19:12:01.434 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547489521434, 2 childs
14-jan-2019 19:12:01.434 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 19:12:01.435 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 19:12:01.435 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 19:12:01.436 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor initialized, refreshing
14-jan-2019 19:12:01.437 [TRACE] [inding.onewire.internal.handler.OwBaseThingHandler] - refreshing onewire:temperature:mybridge:chStudy
14-jan-2019 19:12:01.437 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 19:12:01.438 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType PRESENT, size 40, controlFlags 0x00000124, payload '28.984CDE030000'
14-jan-2019 19:12:01.441 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 0, size 32, controlFlags 0x00000124, payload '(�L�???6'
14-jan-2019 19:12:01.441 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - presence 28.984CDE030000 : ON
14-jan-2019 19:12:01.442 [TRACE] [inding.onewire.internal.handler.OwBaseThingHandler] - refreshing sensor 0 (28.984CDE030000)
14-jan-2019 19:12:01.443 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - owServerConnection already open, skipping input buffer
14-jan-2019 19:12:01.443 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType READ, size 53, controlFlags 0x00000104, payload '/28.984CDE030000/temperature'
14-jan-2019 19:12:02.446 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 0, size 23, controlFlags 0x00000000, payload ''
14-jan-2019 19:12:03.448 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 0, size 23, controlFlags 0x00000000, payload ''
14-jan-2019 19:12:03.682 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code 12, size 36, controlFlags 0x00000104, payload ' 16.125'
14-jan-2019 19:12:03.683 [TRACE] [.smarthome.binding.onewire.internal.device.DS18x20] - read temperature 16.125 °C from 28.984CDE030000
LOG with no sensors responding
14-jan-2019 16:24:12.262 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - timeout - setting error code to -1
14-jan-2019 16:24:12.262 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - closing connection because persistence was denied
14-jan-2019 16:24:12.263 [DEBUG] [nding.onewire.internal.owserver.OwserverConnection] - closed connection
14-jan-2019 16:24:12.263 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - presence 26.23B32E010000 : OFF
14-jan-2019 16:24:12.264 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 16:24:12.264 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor initialized, refreshing
14-jan-2019 16:24:13.266 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547479453266, 2 childs
14-jan-2019 16:24:13.267 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 16:24:13.267 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 16:24:13.268 [DEBUG] [nding.onewire.internal.owserver.OwserverConnection] - opened OwServerConnection to 127.0.0.1:4304
14-jan-2019 16:24:13.270 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType PRESENT, size 40, controlFlags 0x00000124, payload '26.23B32E010000'
14-jan-2019 16:24:13.292 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code -1, size 24, controlFlags 0x00000124, payload ''
14-jan-2019 16:24:16.296 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - timeout - setting error code to -1
14-jan-2019 16:24:16.297 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - closing connection because persistence was denied
14-jan-2019 16:24:16.297 [DEBUG] [nding.onewire.internal.owserver.OwserverConnection] - closed connection
14-jan-2019 16:24:16.298 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - presence 26.23B32E010000 : OFF
14-jan-2019 16:24:16.298 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Temperature sensor (1 to go)
14-jan-2019 16:24:16.298 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Temperature sensor initialized, refreshing
14-jan-2019 16:24:16.299 [TRACE] [inding.onewire.internal.handler.OwBaseThingHandler] - refreshing onewire:temperature:mybridge:chStudy
14-jan-2019 16:24:16.302 [DEBUG] [nding.onewire.internal.owserver.OwserverConnection] - opened OwServerConnection to 127.0.0.1:4304
14-jan-2019 16:24:16.303 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType PRESENT, size 40, controlFlags 0x00000124, payload '28.984CDE030000'
14-jan-2019 16:24:16.322 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code -1, size 24, controlFlags 0x00000124, payload ''
14-jan-2019 16:24:19.326 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - timeout - setting error code to -1
14-jan-2019 16:24:19.326 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - closing connection because persistence was denied
14-jan-2019 16:24:19.326 [DEBUG] [nding.onewire.internal.owserver.OwserverConnection] - closed connection
14-jan-2019 16:24:19.327 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - presence 28.984CDE030000 : OFF
14-jan-2019 16:24:19.327 [TRACE] [inding.onewire.internal.handler.OwBaseThingHandler] - sensor not present
14-jan-2019 16:24:20.328 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - called owRefresher at 1547479460327, 2 childs
14-jan-2019 16:24:20.328 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - getting handler for Multisensor BMS (2 to go)
14-jan-2019 16:24:20.328 [TRACE] [nding.onewire.internal.handler.OwBaseBridgeHandler] - Multisensor BMS initialized, refreshing
14-jan-2019 16:24:20.330 [DEBUG] [nding.onewire.internal.owserver.OwserverConnection] - opened OwServerConnection to 127.0.0.1:4304
14-jan-2019 16:24:20.331 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - wrote: messageType PRESENT, size 40, controlFlags 0x00000124, payload '26.23B32E010000'
14-jan-2019 16:24:20.353 [TRACE] [nding.onewire.internal.owserver.OwserverConnection] - read: return code -1, size 24, controlFlags 0x00000124, payload ''
