I checked the paper documentation of the sensor and it also says AMS in the title (AMS-THS-2IO-A10-211-BRK). So it looks like it is a ASM sensor.
Herman
Herman
Hi Jan, have since a while the strange behavor (I think since I updated to latest build) that I loose some sensors (typically 2) randomly and when I restart opehab all works fine for a while. since I used the latest version you posted here it is better but same issue again.
In the event log
2019-02-01 15:45:37.939 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_CF2015000000’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): refresh exception
2019-02-01 15:45:37.959 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_2E4403000000’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): slave missing <
When I disable the thing and enable it again in paper ui
2019-02-01 19:45:34.711 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_2E4403000000’ changed from OFFLINE (COMMUNICATION_ERROR): slave missing to UNINITIALIZED
2019-02-01 19:45:34.740 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_2E4403000000’ changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2019-02-01 19:45:37.939 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_CF2015000000’ changed from OFFLINE (COMMUNICATION_ERROR): refresh exception to UNINITIALIZED
2019-02-01 19:45:37.952 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_CF2015000000’ changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2019-02-01 19:45:51.024 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_2E4403000000’ changed from UNINITIALIZED (DISABLED) to INITIALIZING
2019-02-01 19:45:51.044 [me.event.ThingUpdatedEvent] - Thing ‘onewire:digitalio2:32e931a4:3A_2E4403000000’ has been updated.
2019-02-01 19:45:51.049 [hingStatusInfoChangedEvent] - ‘onewire:digitalio2:32e931a4:3A_2E4403000000’ changed from INITIALIZING to UNKNOWN
I’m running owfs on another rasppi and have openhab 1 running and there no issues with the sensors.
Thanks a lot for any hint
The interesting question is: why is there a refresh exception in the first place. I‘ll think about that.
Edit: are the other sensors still refreshing when this happens?
strange since I have this version installed (at least I think so as I never seen this bevfore)
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-onewire1’
but around the time the 2 failed there is no other entry in the event log
around the time the sensors failed in openhab.log
2019-02-01 15:45:38.037 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.NumberFormatException: null
at java.math.BigDecimal.(BigDecimal.java:494) ~[?:?]
at java.math.BigDecimal.(BigDecimal.java:383) ~[?:?]
at java.math.BigDecimal.(BigDecimal.java:806) ~[?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.(DecimalType.java:57) ~[?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.valueOf(DecimalType.java:71) ~[?:?]
at org.openhab.binding.onewire.internal.owserver.OwserverConnection.readDecimalType(OwserverConnection.java:175) ~[?:?]
at org.openhab.binding.onewire.internal.handler.OwserverBridgeHandler.readDecimalType(OwserverBridgeHandler.java:150) ~[?:?]
at org.openhab.binding.onewire.internal.handler.OwBaseBridgeHandler.readBitSet(OwBaseBridgeHandler.java:193) ~[?:?]
at org.openhab.binding.onewire.internal.device.AbstractDigitalOwDevice.refresh(AbstractDigitalOwDevice.java:103) ~[?:?]
at org.openhab.binding.onewire.internal.handler.OwBaseThingHandler.refresh(OwBaseThingHandler.java:234) ~[?:?]
at org.openhab.binding.onewire.internal.handler.OwBaseBridgeHandler.refresh(OwBaseBridgeHandler.java:80) ~[?:?]
at org.openhab.binding.onewire.internal.handler.OwBaseBridgeHandler.lambda$0(OwBaseBridgeHandler.java:54) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
Ok. So something is read from the owserver but that could not be converted to a number. I can try to catch that and print out what is wrong. Then the sensors should continue to work.
Thx a lot … changing the binding brought all things online again … will check and report … have a nice evening … KR
since yesterday evening no issues
Thanks. Glad it works for you.
But I fear that this only masks another problem: after an exception during refresh the refresh task is cancelled and not re-installed. I‘ll have another look.
