Hi there,
I am trying to add the Nodon SIN-2-RS-01 actuator to OpenHab.
It does indeed get discovered and added via Openocean and a new Thing is added. Moreover I get live position-updates while moving the blinds up and down via a physical switch.
Unfortunately I canāt seem to get the control via Openhab to work. The blinds do not move while controlling Openhab. The Log looks like this:
2018-11-17 18:25:38.735 [ome.event.ItemCommandEvent] - Item āRollo_Rollershutter2ā received command DOWN
2018-11-17 18:25:38.743 [DEBUG] [nal.transceiver.OpenOceanTransceiver] - Enqueue new send request with ESP3 type RADIO_ERP1 without callback
2018-11-17 18:25:38.762 [DEBUG] [nal.transceiver.OpenOceanTransceiver] - RESPONSE with code RET_OK payload 00
When moving the blinds with a physical switch, the log shows:
2018-11-17 18:27:04.902 [DEBUG] [nal.transceiver.OpenOceanTransceiver] - RADIO_ERP1 with RORG RPS for FEF74796 payload F650FEF747963001FFFFFFFF5300
2018-11-17 18:27:04.911 [DEBUG] [an.handler.OpenOceanBaseThingHandler] - ESP Packet payload F650FEF7479630 for FEF74796 received
2018-11-17 18:27:04.953 [vent.ItemStateChangedEvent] - openocean_rollershutter_usb300_FEF74796_receivingState changed from Rssi 85, repeated 0 to Rssi 83, repeated 0
2018-11-17 18:27:04.964 [vent.ItemStateChangedEvent] - Rollo_ReceivingState changed from Rssi 85, repeated 0 to Rssi 83, repeated 0
2018-11-17 18:27:05.045 [DEBUG] [nal.transceiver.OpenOceanTransceiver] - RADIO_ERP1 with RORG VLD for 050EEF18 payload D211000004050EEF180001FFFFFFFF3A00
2018-11-17 18:27:05.047 [DEBUG] [an.handler.OpenOceanBaseThingHandler] - ESP Packet payload D211000004050EEF1800 for 050EEF18 received
2018-11-17 18:27:05.064 [vent.ItemStateChangedEvent] - Rollo_Rollershutter2 changed from 10 to 17
2018-11-17 18:27:05.068 [vent.ItemStateChangedEvent] - Rollo_ReceivingState2 changed from Rssi 61, repeated 0 to Rssi 58, repeated 0
2018-11-17 18:27:05.077 [DEBUG] [nal.transceiver.OpenOceanTransceiver] - RADIO_ERP1 with RORG RPS for FEF74796 payload F600FEF747962001FFFFFFFF5300
2018-11-17 18:27:05.081 [DEBUG] [an.handler.OpenOceanBaseThingHandler] - ESP Packet payload F600FEF7479620 for FEF74796 received
May someone can help me to find out how to control the blinds via Openhab?
Thanks!!
