Thank you very much for the new EnOcean Binding
I use an Eltako Rocker Switch FT55 to switch between 4 light scenes of my light panel (Hue:0210 âŠ) in my kitchen. Most of it works fine except a minor thing. When I release the rocker switch button the color temperature always changed from 100 to 87 even it should stay 100, as you can see from the log
2019-03-18 12:48:32.132 [vent.ChannelTriggeredEvent] - enocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchA triggered DIR2_PRESSED
2019-03-18 12:48:32.143 [ome.event.ItemCommandEvent] - Item âTaster_Kueche_linksâ received command OFF
2019-03-18 12:48:32.147 [nt.ItemStatePredictedEvent] - Taster_Kueche_links predicted to become OFF
2019-03-18 12:48:32.152 [vent.ItemStateChangedEvent] - Taster_Kueche_links changed from ON to OFF
2019-03-18 12:48:32.154 [ome.event.ItemCommandEvent] - Item âLicht_EG_Panel_Kueche_KWâ received command 100
2019-03-18 12:48:32.159 [ome.event.ItemCommandEvent] - Item âLicht_EG_Panel_Kuecheâ received command 100
2019-03-18 12:48:32.166 [nt.ItemStatePredictedEvent] - Licht_EG_Panel_Kueche_KW predicted to become 100
2019-03-18 12:48:32.175 [nt.ItemStatePredictedEvent] - Licht_EG_Panel_Kueche predicted to become 100
2019-03-18 12:48:32.182 [vent.ItemStateChangedEvent] - Licht_EG_Panel_Kueche_KW changed from 87 to 100
2019-03-18 12:48:32.185 [vent.ItemStateChangedEvent] - Licht_EG_Panel_Kueche changed from 0 to 100
2019-03-18 12:48:32.383 [vent.ChannelTriggeredEvent] - enocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchA triggered DIR2_RELEASED
2019-03-18 12:48:33.374 [vent.ItemStateChangedEvent] - Licht_EG_Panel_Kueche_KW changed from 100 to 87
I use the following item definition
Switch Taster_Kueche_links âTaster KĂŒche linksâ { channel=âenocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchAâ }
Switch Taster_Kueche_rechts âTaster KĂŒche rechtsâ { channel=âenocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchBâ }
and the following rules
// KĂŒchenlicht aus -AUS
rule âKuechenTaster links obenâ
when Channel âenocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchAâ triggered âDIR1_PRESSEDâ
Licht_EG_Panel_Kueche_KW.sendCommand(100)
Licht_EG_Panel_Kueche.sendCommand(0)
end// KĂŒchenlicht hell warmweiĂ - Romantik
rule âKuechenTaster links untenâ
when Channel âenocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchAâ triggered âDIR2_PRESSEDâ
Licht_EG_Panel_Kueche.sendCommand(100)
end// KĂŒchenlicht warmweiĂ gedimmt - Nachtlicht
rule âKuechenTaster rechts obenâ
when Channel âenocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchBâ triggered âDIR1_PRESSEDâ
Licht_EG_Panel_Kueche.sendCommand(30)
end// KĂŒchenlicht hell kaltweiĂ - Arbeiten
rule âKuechenTaster rechts untenâ
when Channel âenocean:rockerSwitch:A60149OK:FEF8B1BF:rockerswitchBâ triggered âDIR2_PRESSEDâ
Licht_EG_Panel_Kueche_KW.sendCommand(0)
Any idea how to solve this issue? Iâm not sure if the issue is EnOcean or Hue related.
⊠If I use the OH App on my tablet I can change the color temperature to 100 and it stays 100
