Hi everybody,
I have a question regarding an issue I discovered during a long term test period with an eltako/openhab 3 testbench setting. I have several Eltako devices installed (FAM14, FGW14-USB, FUD14, FSB14, FSR14-4x, FTS14EM) and those are connected to OH3 via the FGW14-USB Gateway. With one rocker switch connected to the FTS14EM I created a scene switch to count through different light scenes (managed by rules, in principle like here). So far this setting works very good without any problems.
Anyway, sometimes when i press the rocker switch to change the scene, or another switch (controls also a rule) which is connected to the FTS14EM nothing happens. When I look to the log there is really “nothing”. I get no “PRESSED” or “RELEASED” state in the log. The small status LEDs on the Eltako devices show me, that the button press is recognized by the FTS14EM and send via the RS485 bus to the FGW14-USB.
As mentioned above, another switch (no scene button) does also not response. I can’t detect no pattern behind the behaviour.
I changed the log already to DEBUG but there are also no entries.
More curious, changing the scene states from within OH3 Main UI is further possible.
Rebooting the Raspberry or restarting openhab service solve the issue, but this can’t be the final solution.
I don’t know if this is important, but yesterday before this happend i got an Log entry from the HP Printer Binding as follows:
2021-12-11 18:33:40.913 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Total timeout 10000 ms elapsed
2021-12-11 18:33:40.983 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from OFFLINE (COMMUNICATION_ERROR): Total timeout 10000 ms elapsed to ONLINE
2021-12-11 18:33:45.156 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from ONLINE to OFFLINE
2021-12-11 18:33:45.161 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from OFFLINE to OFFLINE
2021-12-11 18:33:45.210 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from OFFLINE to ONLINE
2021-12-11 18:33:55.210 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from ONLINE to OFFLINE
2021-12-11 18:33:55.213 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from OFFLINE to OFFLINE
2021-12-11 18:33:55.291 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from OFFLINE to UNINITIALIZED
2021-12-11 18:33:55.308 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'hpprinter:printer:77c1526f6b' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
Does anyone observed a same behaviour or has anyone an idea whats might the problem?
Hardware/Software information:
Raspberry Pi 4 Model B Rev 1.1
Eltako (see above)
Openhab 3.1.0 stable release
Enocean Binding 3.1.0 (official from OH3)
Best regards and many thanks in advance
Stefan
