Java Runtime Environment: what ever Openhabian installed
openHAB version: latest build
Issue of the topic: No SSH or console access
the install appears to have run sucessullly. I can get to the logs at ip:9001 and the default configuration screen at ip:8080. Samba shares work as well.
the issue is that i don’t have SSH or console access using openhabian/openhabian. any suggestions?
For SSH, I have tried terminal on a Mac and Putty on Windows 10.
I am not a linux expert, hence the Pi and Openhabian route.
I just ran ssh openhabian@192.168.200.132 -v
and it looks like the connection succeeds but with my mac username
there are a bunch of rsa and dosa cert lines with key_load_public: no such file or directory but it ends with the following
debug1: Local version string SSH-2.0-OpenSSH_7.6
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1 Raspbian-5+deb8u4
debug1: match: OpenSSH_6.7p1 Raspbian-5+deb8u4 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 192.168.200.132:22 as 'openhabian’
debug1: SSH2_MSG_KEXINIT sent
Connection reset by 192.168.200.132 port 22
Well, until you can log in on the console ssh is never going to work.
I’m at a loss. All I can think is either the password changed and the docs haven’t caught up, or something went wrong with your install and configuration. I just looked at the script and the default password is the same as it always was so I’m thinking something went wrong during the setup.
You can try to run the install from scratch again (if one thing went wrong it is likely more went wrong as well) or you can follow the instructions in the following link to boot into single user mode and change the password for openhabian.
