Hello everybody,
i actual set up a new openhabian installation on my new raspberry PI 4 model B.
I do that steps:
• Download the latest “openHABianPi” SD card image file (Note: the file is xz compressed)
• Write the image to your SD card (e.g. with Etcher, able to directly work with xz files)
• Insert the SD card into the Raspberry Pi, connect Ethernet (Wi-Fi supported) and power
and it works fine so far. (2.4.0 release build)
I can access the webpage via http://openhab:8080/
But i have 2 questions:
First question:
When i take a look to the Logviewer, the Dashboard starts twice with different ports.
Is that right or why do it start twice ?
-2019-10-31 10:37:22.929 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard
at http://192.168.xxx.xx:8080
- 2019-10-31 10:37:22.931 [INFO ] [.dashboard.internal.DashboardService] - Started
Dashboard at https://192.168.xxx.xx:8443
Second question:
I installed the optional Package NodeRed with openhabian-config. This works fine too.
But on the Openhab Dashboard there is no tile for node red.
Any ideas why it not appears at the Dahboard and what to do for creating a NodeRed tile ?
Many thanks in advance
Christian
