My knx.things-file - I dont think there are problems in it.
The Problem also appears, when i follow the “less is more” and reduce the bridge-part to 1 or 2 lines (at least the ip).
Bridge knx:ip:KNXROUTER "KNX/IP Router" @ "KNX" [
ipAddress="[my routers ip]",
localIp="[the ip of my openhab server]",
type="TUNNEL",
portNumber="3671",
responseTimeout=30,
readingPause=50,
readRetriesLimit=50,
autoReconnectPeriod=60,
localSourceAddress="1.0.250"
Thing device generic [
readInterval=0
Type switch : licht_alles_aus "Licht aus" [ ga="1/0/0+<1/0/0" ]
Type switch : licht_szene_schlafen_aus "Szene: Schlafen, Lichter aus" [ ga="1/0/10+<1/0/10" ]
Type switch : Raffstore_komplett "Raffstore Komplett" [ ga="1/1/10+<3/0/55" ]
Type rollershutter : Lamellen_Komplett "Lamellen Komplett" [ upDown="1/1/10+<3/0/55", stopMove="1/1/11+1/1/11", position="1/1/5+<3/0/76" ]
Thing device dimmaktor_1_2_25 [
address="1.2.25",
fetch=false,
pingInterval=300,
readInterval=3600
Type dimmer : Channel_A "Dimmer, EG, 108-30 / Wohnen //Hifi-Rack" [ switch="2/0/40+<2/3/40", position="2/2/40+<2/4/40", increaseDecrease="2/1/40" ]
Type dimmer : Channel_B "Dimmer, EG, 108-31 / Arbeiten // Hinten" [ switch="2/0/41+<2/3/41", position="2/2/41+<2/4/41", increaseDecrease="2/1/41" ]
Type dimmer : Channel_C "Dimmer, EG, 109-30 / Küche // Arbeitsfläche" [ switch="2/0/53+<2/3/53", position="2/2/53+<2/4/53", increaseDecrease="2/1/53" ]
Type dimmer : Channel_D "Dimmer, EG, 108-32 / Wohnen // Couch" [ switch="2/0/42+<2/3/42", position="2/2/42+<2/4/42", increaseDecrease="2/1/42" ]
Type switch : Error "Gerätefehler Dimmaktor 1.2.25" [ ga="0/1/9+<0/1/9" ]
Thing device dimmaktor_1_2_26 [
address="1.2.26",
fetch=false,
pingInterval=300,
readInterval=3600
Type dimmer : Channel_A "Dimmer, EG, 107-30 / Speisekammer" [ switch="2/0/35+<2/3/35", position="2/2/35+<2/4/35", increaseDecrease="2/1/35" ]
Type dimmer : Channel_B "Dimmer, EG, 106-30 / Kämmerchen // Licht" [ switch="2/0/31+<2/3/31", position="2/2/31+<2/4/31", increaseDecrease="2/1/31" ]
Type dimmer : Channel_C "Dimmer, EG, 104-30 / Flur // Eingang 2" [ switch="2/0/19+<2/3/19", position="2/2/19+<2/4/19", increaseDecrease="2/1/19" ]
Type dimmer : Channel_D "Dimmer, EG, 104-31 / Flur // Eingang 1" [ switch="2/0/20+<2/3/20", position="2/2/20+<2/4/20", increaseDecrease="2/1/20" ]
Type switch : Error "Gerätefehler Dimmaktor 1.2.26" [ ga="0/1/18+<0/1/18" ]
Thing device dimmaktor_1_2_27 [
address="1.2.27",
fetch=false,
pingInterval=300,
readInterval=3600
Type dimmer : Channel_A "Dimmer, EG, 101-30 / Windfang // Licht 1" [ switch="2/0/0+<2/3/0", position="2/2/0+<2/4/0", increaseDecrease="2/1/0" ]
Type dimmer : Channel_B "Dimmer, EG, 101-31 / Windfang // Licht 2" [ switch="2/0/1+<2/3/1", position="2/2/1+<2/4/1", increaseDecrease="2/1/1" ]
Type dimmer : Channel_C "Dimmer, EG, 103-30 / HWR // Licht" [ switch="2/0/13+<2/3/13", position="2/2/13+<2/4/13", increaseDecrease="2/1/13" ]
Type switch : Channel_D "Dimmer, EG, 102-30 / Garage // Licht" [ ga="2/0/7+<2/3/7" ]
Type switch : Error "Gerätefehler Dimmaktor 1.2.27" [ ga="0/1/27+<0/1/27" ]
Thing device dimmaktor_1_2_28 [
address="1.2.28",
fetch=false,
pingInterval=300,
readInterval=3600
Type dimmer : Channel_A "Dimmer, EG, 105-30 / Bad // Licht" [ switch="2/0/26+<2/3/26", position="2/2/26+<2/4/26", increaseDecrease="2/1/26" ]
Type dimmer : Channel_B "Dimmer, EG, 105-30 / Bad // Licht" [ switch="2/0/26+<2/3/26", position="2/2/26+<2/4/26", increaseDecrease="2/1/26" ]
Type dimmer : Channel_C "Dimmer, EG, 109-31 / Küche // Essen" [ switch="2/0/54+<2/3/54", position="2/2/13+<2/4/13", increaseDecrease="2/1/13" ]
Type dimmer : Channel_D "Dimmer, OG, 203-30 / Ankleide // Licht" [ switch="2/0/79+<2/3/79", position="2/2/79+<2/4/79", increaseDecrease="2/1/79" ]
Type switch : Error "Gerätefehler Dimmaktor 1.2.28" [ ga="0/1/36+<0/1/36" ]
Thing device dimmaktor_1_3_25 [
address="1.3.25",
fetch=false,
pingInterval=300,
readInterval=3600
Type dimmer : Channel_A "Dimmer, OG, 201-30 / Flur // Pendel" [ switch="2/0/62+<2/3/62", position="2/2/62+<2/4/62", increaseDecrease="2/1/62" ]
Type dimmer : Channel_B "Dimmer, EG, 108-33 / Essen // Luftraum" [ switch="2/0/43+<2/3/43", position="2/2/43+<2/4/43", increaseDecrease="2/1/43" ]
Type dimmer : Channel_C "Dimmer, EG, 108-34 / Fensterfront" [ switch="2/0/44+<2/3/44", position="2/2/44+<2/4/44", increaseDecrease="2/1/44" ]
Type dimmer : Channel_D "Dimmer, OG, 201-31 / Flur // Licht" [ switch="2/0/63+<2/3/63", position="2/2/63+<2/4/63", increaseDecrease="2/1/63" ]
Type switch : Error "Gerätefehler Dimmaktor 1.3.25" [ ga="0/1/45+<0/1/45" ]
[… and much much more… to big to insert here…]
}Preformatted text
