this will mostly be a networking problem on the virtual switch of the VM host … also don’t understand some configuration here why people still use devices topology address is like working with channels instead of items … also my config is
I already suspect the network because the problems only occurred after the update and restart of the host server.
Do not out set Network address of the local host ip address.
I just made a test on a debian running openhabian script with ooenhab 3.3 with the config trough UI listed above and the VM is running on xcp-ng and no disconnect.
I believe there was an update to hyper-v that broke some stuff try reverting to a previous update of the windows server to check
Check if the Windows NIC is allowed to go to sleep. Also check the Firewall-Log of Windows.
I would suspect something along those lines…
What NIC (Vendor & Model) do you use in the Windows machine?
Good idea. Are you sure? But it says KB5015874 for Windows server 2012.
I will look for deinstallation at Windows server 2016…
… done but nothing changes.
I have run the virtual machine on my local computer (Windows 10) aber the problem ist still the same.
ok then its something with the network switch in your house or CentOS. can you spin a debian with openhabian VM and just add the tunnel with one knx channel
Well, i ment that the NICs should NOT be allowed to go to sleep Unfortunately, sometimes the drivers of te NICs do set this to allow, despite the fact that it is a server.
Good.
The HW is fine. Your problem might be related to the teaming though…I came across weird connection problems on windows server a couple of times, which had been related to NIC teaming. Never really figured out what the root cause was, but getting rid of the teaming solved the connection problems in all cases. Maybe you wanna give this a try, too.
Good idea, but i don’t want to deactivate the team because it’ my server and the test running on my Windows 10 client Hyper-V without NIC-team creates exactly the same error.
So I gave up and reactivated the windows installation from the test phase, transferred the openHAB configuration and it has been running stably for days - easy.
Some update to Windows / Hyper-V definitely broke something.
I ran Home Assistant (yes, HA, not OpenHAB) with a KNX integration flawlessly for 2 years, on a Hyper-V VM running in Windows Server, with I350 NIC.
Then, about 2 months ago, without me changing anything in the systems, I started getting those “Connection Closed” notices and all KNX switches became unresponsive.
If I do a clean install of HA+KNX to a new Hyper-V virtual machine, it still doesn’t work (Connection Closed).
If I restore my existing HA+KNX configuration to a VMWare VM, or RPI… it works.
So, here we have 2 cases where HyperV + KNX stopped working all of the sudden. One running in OpenHAB, the other in Home Assistant.
I tried changing all settings in the Network Adapter, but didn’t get it to work.
Think I’ll try a different NIC.
Did you manage to get your KNX integration to work again?
