Still doesnt work, no one is using these???
Any one?!
Any one?!
nobody is using dyi mode, just reflash it standard way …it takes like 5minutes
Have you seen the size of the pins on the mini?
yes indeed, i have couple of these
Seems Sonoff have a new 3.3 firmware, after I installed that I was able to setup the sonoffDiy network and flash over to Tasmota. Working now! Finally!
I’ve got a mini installed with tasmota but the hardware switch is very hit and miss, sometimes it takes a few goes toggling back and forward to get it to work. Other times it works first time. Any ideas what might fix it?
Hi all,
I managed to get the sonoff mini working with DIY and http1.x binding. Everything is working fine even the physical switch. Maybe this is not the right place for asking, but does someone know if there will be a porting of the http binding to 2.x?
Thanx
I’m fairly sure it is being worked on already, though I don’t remember by who.
