Sorry have not have any time to watch this.
Are you still interested of the jar?
/Mike
/Mike
I am!
Sending Command Refresh is not working.
/Mike
Saw now that you use a non standard way with a separate channel for refresh.
/Mike
Well, I installed the binding then added the things, which are online now. The problem is than things are not receiving any updates.
There is this warning log…
2020-02-09 10:16:15.001 [WARN ] [etcare.internal.SurePetcareAPIHelper] - Exception caught during pet status update: java.lang.NumberFormatException
Any ideas?
You have a number item where it should be text.
//// SurePetcare API Bridge
Switch SurePetcareAPIBridgeOnline "Online state" {channel="surepetcare:bridge:7f9f20ee:online"}
Switch SurePetcareAPIBridgeRefresh "Refresh" {channel="surepetcare:bridge:7f9f20ee:refresh"}
//// SurePetcare Flap Device
Number SurePetcareFlapDeviceId "Id" {channel="surepetcare:flapDevice:087f26b7:id"}
String SurePetcareFlapDeviceName "Name" {channel="surepetcare:flapDevice:087f26b7:name"}
String SurePetcareFlapDeviceProduct "Product type" {channel="surepetcare:flapDevice:087f26b7:product"}
Switch SurePetcareFlapDeviceCurfewEnabled1 "Curfew enabled" {channel="surepetcare:flapDevice:087f26b7:curfewEnabled1"}
String SurePetcareFlapDeviceCurfewLockTime1 "Curfew lock time" {channel="surepetcare:flapDevice:087f26b7:curfewLockTime1"}
String SurePetcareFlapDeviceCurfewUnlockTime1 "Curfew unlock time" {channel="surepetcare:flapDevice:087f26b7:curfewUnlockTime1"}
Switch SurePetcareFlapDeviceCurfewEnabled2 "Curfew enabled" {channel="surepetcare:flapDevice:087f26b7:curfewEnabled2"}
String SurePetcareFlapDeviceCurfewLockTime2 "Curfew lock time" {channel="surepetcare:flapDevice:087f26b7:curfewLockTime2"}
String SurePetcareFlapDeviceCurfewUnlockTime2 "Curfew unlock time" {channel="surepetcare:flapDevice:087f26b7:curfewUnlockTime2"}
Switch SurePetcareFlapDeviceCurfewEnabled3 "Curfew enabled" {channel="surepetcare:flapDevice:087f26b7:curfewEnabled3"}
String SurePetcareFlapDeviceCurfewLockTime3 "Curfew lock time" {channel="surepetcare:flapDevice:087f26b7:curfewLockTime3"}
String SurePetcareFlapDeviceCurfewUnlockTime3 "Curfew unlock time" {channel="surepetcare:flapDevice:087f26b7:curfewUnlockTime3"}
Switch SurePetcareFlapDeviceCurfewEnabled4 "Curfew enabled" {channel="surepetcare:flapDevice:087f26b7:curfewEnabled4"}
String SurePetcareFlapDeviceCurfewLockTime4 "Curfew lock time" {channel="surepetcare:flapDevice:087f26b7:curfewLockTime4"}
String SurePetcareFlapDeviceCurfewUnlockTime4 "Curfew unlock time" {channel="surepetcare:flapDevice:087f26b7:curfewUnlockTime4"}
String SurePetcareFlapDeviceLockingMode "Locking mode" {channel="surepetcare:flapDevice:087f26b7:lockingMode"}
Switch SurePetcareFlapDeviceLowBattery "Low battery" {channel="surepetcare:flapDevice:087f26b7:lowBattery"}
Number SurePetcareFlapDeviceBatteryLevel "Battery level" {channel="surepetcare:flapDevice:087f26b7:batteryLevel"}
Number SurePetcareFlapDeviceBatteryVoltage "Battery voltage" {channel="surepetcare:flapDevice:087f26b7:batteryVoltage"}
Switch SurePetcareFlapDeviceOnline "Online state" {channel="surepetcare:flapDevice:087f26b7:online"}
Number SurePetcareFlapDeviceDeviceRSSI "Signal strength device (rssi)" {channel="surepetcare:flapDevice:087f26b7:deviceRSSI"}
Number SurePetcareFlapDeviceHubRSSI "Signal strength hub (rssi)" {channel="surepetcare:flapDevice:087f26b7:hubRSSI"}
//// SurePetcare Household
Number SurePetcareHouseholdId "Id" {channel="surepetcare:household:fcbc0e0c:id"}
String SurePetcareHouseholdName "Name" {channel="surepetcare:household:fcbc0e0c:name"}
Number SurePetcareHouseholdTimezoneId "Timezone" {channel="surepetcare:household:fcbc0e0c:timezoneId"}
//// SurePetcare Hub Device
Number SurePetcareHubDeviceId "Id" {channel="surepetcare:hubDevice:f7d6336e:id"}
String SurePetcareHubDeviceName "Name" {channel="surepetcare:hubDevice:f7d6336e:name"}
String SurePetcareHubDeviceProduct "Product type" {channel="surepetcare:hubDevice:f7d6336e:product"}
String SurePetcareHubDeviceLedMode "Led mode" {channel="surepetcare:hubDevice:f7d6336e:ledMode"}
String SurePetcareHubDevicePairingMode "Pairing mode" {channel="surepetcare:hubDevice:f7d6336e:pairingMode"}
Switch SurePetcareHubDeviceOnline "Online state" {channel="surepetcare:hubDevice:f7d6336e:online"}
//// SurePetcare Pet
Number SurePetcarePetId "Id" {channel="surepetcare:pet:cc0397a6:id"}
String SurePetcarePetName "Name" {channel="surepetcare:pet:cc0397a6:name"}
String SurePetcarePetComment "Comments" {channel="surepetcare:pet:cc0397a6:comment"}
String SurePetcarePetGender "Gender" {channel="surepetcare:pet:cc0397a6:gender"}
String SurePetcarePetBreed "Breed" {channel="surepetcare:pet:cc0397a6:breed"}
String SurePetcarePetSpecies "Species" {channel="surepetcare:pet:cc0397a6:species"}
Image SurePetcarePetPhoto "Pet photo" {channel="surepetcare:pet:cc0397a6:photo"}
String SurePetcarePetTagIdentifier "Micro chip tag identifier" {channel="surepetcare:pet:cc0397a6:tagIdentifier"}
String SurePetcarePetLocation "Location" {channel="surepetcare:pet:cc0397a6:location"}
DateTime SurePetcarePetLocationChanged "Last location change time" {channel="surepetcare:pet:cc0397a6:locationChanged"}
String SurePetcarePetLocationTimeoffset "Location change time offset" {channel="surepetcare:pet:cc0397a6:locationTimeoffset"}
String SurePetcarePetLocationChangedThrough "Last location changed by" {channel="surepetcare:pet:cc0397a6:locationChangedThrough"}
DateTime SurePetcarePetDateOfBirth "Pet birthday" {channel="surepetcare:pet:cc0397a6:dateOfBirth"}
Number:Mass SurePetcarePetWeight "Pet weight" {channel="surepetcare:pet:cc0397a6:weight"}
String SurePetcarePetFeederDevice "Pet feeding device name" {channel="surepetcare:pet:cc0397a6:feederDevice"}
DateTime SurePetcarePetFeederLastFeeding "Pet last feeding" {channel="surepetcare:pet:cc0397a6:feederLastFeeding"}
Number:Mass SurePetcarePetFeederLastChange "Pet feeding last change" {channel="surepetcare:pet:cc0397a6:feederLastChange"}
Number:Mass SurePetcarePetFeederLastChangeLeft "Pet feeding last change left" {channel="surepetcare:pet:cc0397a6:feederLastChangeLeft"}
Number:Mass SurePetcarePetFeederLastChangeRight "Pet feeding last change right" {channel="surepetcare:pet:cc0397a6:feederLastChangeRight"}
So , I tried to find the problem without success.
This are my items that were created in VSC with Openhab extention.
It is funny that none of the items is receiving any kind of update!
I dont know what to do anymore…
Any idea?
Here is the log with an warning at the end. I disabled and then enabled API Bridge through Paper ui.
After that there are no updates, just repeating warning: Exception caught during pet status update: java.lang.NumberFormatException
2020-03-23 20:10:01.721 [hingStatusInfoChangedEvent] - 'surepetcare:bridge:7f9f20ee' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2020-03-23 20:10:01.758 [hingStatusInfoChangedEvent] - 'surepetcare:bridge:7f9f20ee' changed from INITIALIZING to UNKNOWN
2020-03-23 20:10:01.788 [hingStatusInfoChangedEvent] - 'surepetcare:household:fcbc0e0c' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-03-23 20:10:01.791 [hingStatusInfoChangedEvent] - 'surepetcare:hubDevice:f7d6336e' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-03-23 20:10:01.801 [vent.ItemStateChangedEvent] - surepetcare_bridge_7f9f20ee_online changed from OFF to ON
2020-03-23 20:10:01.806 [vent.ItemStateChangedEvent] - SurePetcareAPIBridgeOnline changed from OFF to ON
2020-03-23 20:10:01.816 [hingStatusInfoChangedEvent] - 'surepetcare:pet:cc0397a6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-03-23 20:10:01.826 [hingStatusInfoChangedEvent] - 'surepetcare:flapDevice:087f26b7' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-03-23 20:10:01.842 [hingStatusInfoChangedEvent] - 'surepetcare:household:fcbc0e0c' changed from INITIALIZING to ONLINE
2020-03-23 20:10:01.867 [hingStatusInfoChangedEvent] - 'surepetcare:hubDevice:f7d6336e' changed from INITIALIZING to ONLINE
2020-03-23 20:10:01.872 [hingStatusInfoChangedEvent] - 'surepetcare:pet:cc0397a6' changed from INITIALIZING to ONLINE
2020-03-23 20:10:01.878 [hingStatusInfoChangedEvent] - 'surepetcare:flapDevice:087f26b7' changed from INITIALIZING to ONLINE
2020-03-23 20:10:02.689 [vent.ItemStateChangedEvent] - systeminfo_computer_openHABianPi_sensors_cpuTemp changed from 42.4 to 42.9
2020-03-23 20:10:03.898 [WARN ] [etcare.internal.SurePetcareAPIHelper] - Exception caught during topology cache update: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.devices[1].control.curfew
2020-03-23 20:10:03.926 [hingStatusInfoChangedEvent] - 'surepetcare:bridge:7f9f20ee' changed from UNKNOWN to ONLINE
I think you are missing the bridge id for all the items
Atleast thats how my working config is set up
should be
Number SurePetcareFlapDeviceId "Id" {channel="surepetcare:flapDevice:7f9f20ee:087f26b7:id"}
Thank for sugestion. After correcting all items and restarting the binding the same two warnings apear:
at the start:
020-04-20 17:12:02.446 [WARN ] [etcare.internal.SurePetcareAPIHelper] - Exception caught during topology cache update: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.devices[1].control.curfew
and reapiting one:
2020-04-20 17:17:02.701 [WARN ] [etcare.internal.SurePetcareAPIHelper] - Exception caught during pet status update: java.lang.NumberFormatException
Hi @Osmii. What kind of flap do you have, cat flap or pet flap?
From the error message above, it seems the API returns a single curfew element, whereas the binding expects a list of curfews.
Have you set a curfew in the Sure Petcare App? If not, could you try adding a curfew and then remove it again?
If that doesn’t help, you might need to up the log level and send me the output of your API call.
Kind regards,
Rene
Hi Rene.
I have cat flap. I enebled and disabled curfew a few times with no respones from binding.
How do I up log level to se the output of API call?
Thank you!
Could you try to restart openhab, so that the binding gets properly restarted and check if you still get the same “java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.devices[1].control.curfew” error message.
openhab-cli console
(enter password, default is “habopen”)
openhab> log:set DEBUG org.openhab.binding.surepetcare.internal
openhab> bundle:restart org.openhab.binding.surepetcare
Here it is…
2020-04-23 21:18:11.439 [DEBUG] [etcare.internal.SurePetcareAPIHelper] - API execution successful, response: {"data":[{"id":6381,"name":"Mi\u0161a","gender":0,"weight":"NaN","household_id":2948,"species_id":1,"tag_id":3281,"version":"Mw==","created_at":"2018-01-23T15:39:34+00:00","updated_at":"2018-01-23T15:41:11+00:00","status":{"activity":{"tag_id":3281,"device_id":68233,"where":1,"since":"2020-04-23T16:53:44+00:00"}}},{"id":6382,"name":"\u017du\u017eu","gender":0,"weight":"NaN","household_id":2948,"species_id":1,"tag_id":3282,"version":"Mw==","created_at":"2018-01-23T15:39:34+00:00","updated_at":"2018-01-23T15:41:35+00:00","status":{"activity":{"tag_id":3282,"device_id":68233,"where":2,"since":"2020-04-23T19:15:19+00:00"}}},{"id":6383,"name":"Kepek","gender":1,"weight":"NaN","household_id":2948,"species_id":1,"tag_id":3283,"version":"Mw==","created_at":"2018-01-23T15:39:35+00:00","updated_at":"2018-01-23T15:41:52+00:00","status":{"activity":{"tag_id":3283,"device_id":68233,"where":2,"since":"2020-04-23T12:12:45+00:00"}}},{"id":17072,"name":"Belka","gender":0,"household_id":2948,"species_id":1,"tag_id":12731,"version":"Mg==","created_at":"2018-08-09T14:55:53+00:00","updated_at":"2018-08-09T15:02:06+00:00","status":{"activity":{"tag_id":12731,"device_id":68233,"where":1,"since":"2020-04-23T18:12:09+00:00"}}}]}
2020-04-23 21:18:11.445 [WARN ] [etcare.internal.SurePetcareAPIHelper] - Exception caught during pet status update: java.lang.NumberFormatException
2020-04-23 21:18:11.447 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Updating pet status for: 2bf0dbd6
2020-04-23 21:18:11.449 [DEBUG] [ternal.handler.SurePetcarePetHandler] - Trying to update unknown pet: 2bf0dbd6
After that I renabled binding
2020-04-23 21:23:45.075 [DEBUG] [e.internal.SurePetcareHandlerFactory] - createHandler - create handler for org.eclipse.smarthome.core.thing.internal.BridgeImpl@ad2b6a69
2020-04-23 21:23:45.108 [DEBUG] [iscovery.SurePetcareDiscoveryService] - Starting Sure Petcare household discovery
2020-04-23 21:23:45.113 [DEBUG] [iscovery.SurePetcareDiscoveryService] - Scheduled topology-changed job every 12 hours
2020-04-23 21:23:45.135 [hingStatusInfoChangedEvent] - 'surepetcare:bridge:7f9f20ee' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2020-04-23 21:23:45.178 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Initializing Sure Petcare bridge handler.
2020-04-23 21:23:45.185 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Login to SurePetcare API with username:
2020-04-23 21:23:45.185 [DEBUG] [e.internal.SurePetcareHandlerFactory] - createHandler - create handler for org.eclipse.smarthome.core.thing.internal.ThingImpl@b5708fd
2020-04-23 21:23:45.186 [DEBUG] [e.internal.SurePetcareHandlerFactory] - createHandler - create handler for org.eclipse.smarthome.core.thing.internal.ThingImpl@13a7d6e3
2020-04-23 21:23:45.189 [DEBUG] [nal.handler.SurePetcareDeviceHandler] - Created device handler for type surepetcare:flapDevice
2020-04-23 21:23:45.192 [DEBUG] [etcare.internal.SurePetcareAPIHelper] - current MAC address: , device id:
2020-04-23 21:23:45.186 [DEBUG] [e.internal.SurePetcareHandlerFactory] - createHandler - create handler for org.eclipse.smarthome.core.thing.internal.ThingImpl@d519babf
2020-04-23 21:23:45.186 [DEBUG] [e.internal.SurePetcareHandlerFactory] - createHandler - create handler for org.eclipse.smarthome.core.thing.internal.ThingImpl@ccd98eff
2020-04-23 21:23:45.204 [DEBUG] [nal.handler.SurePetcareDeviceHandler] - Created device handler for type surepetcare:hubDevice
2020-04-23 21:23:45.229 [hingStatusInfoChangedEvent] - 'surepetcare:bridge:7f9f20ee' changed from INITIALIZING to UNKNOWN
2020-04-23 21:23:45.246 [hingStatusInfoChangedEvent] - 'surepetcare:household:fcbc0e0c' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-04-23 21:23:45.255 [hingStatusInfoChangedEvent] - 'surepetcare:hubDevice:f7d6336e' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-04-23 21:23:45.265 [hingStatusInfoChangedEvent] - 'surepetcare:pet:2bf0dbd6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-04-23 21:23:45.270 [hingStatusInfoChangedEvent] - 'surepetcare:household:fcbc0e0c' changed from INITIALIZING to ONLINE
2020-04-23 21:23:45.275 [hingStatusInfoChangedEvent] - 'surepetcare:flapDevice:087f26b7' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-04-23 21:23:45.284 [hingStatusInfoChangedEvent] - 'surepetcare:pet:2bf0dbd6' changed from INITIALIZING to ONLINE
2020-04-23 21:23:45.288 [hingStatusInfoChangedEvent] - 'surepetcare:hubDevice:f7d6336e' changed from INITIALIZING to ONLINE
2020-04-23 21:23:45.293 [hingStatusInfoChangedEvent] - 'surepetcare:flapDevice:087f26b7' changed from INITIALIZING to ONLINE
2020-04-23 21:23:45.434 [DEBUG] [etcare.internal.SurePetcareAPIHelper] - Login successful, token:
2020-04-23 21:23:45.436 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Login successful, updating topology cache
2020-04-23 21:23:46.012 [DEBUG] [etcare.internal.SurePetcareAPIHelper] - API execution successful, response: {
2020-04-23 21:23:46.023 [WARN ] [etcare.internal.SurePetcareAPIHelper] - Exception caught during topology cache update: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.devices[1].control.curfew
2020-04-23 21:23:46.026 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Cache update successful, setting bridge status to ONLINE
2020-04-23 21:23:46.033 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Updating 4 connected things
2020-04-23 21:23:46.033 [hingStatusInfoChangedEvent] - 'surepetcare:bridge:7f9f20ee' changed from UNKNOWN to ONLINE
2020-04-23 21:23:46.035 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Thing: surepetcare:flapDevice, id: 087f26b7
2020-04-23 21:23:46.038 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Thing: surepetcare:household, id: fcbc0e0c
2020-04-23 21:23:46.042 [DEBUG] [.handler.SurePetcareHouseholdHandler] - Trying to update unknown household: fcbc0e0c
2020-04-23 21:23:46.045 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Thing: surepetcare:pet, id: 2bf0dbd6
2020-04-23 21:23:46.048 [DEBUG] [ternal.handler.SurePetcarePetHandler] - Trying to update unknown pet: 2bf0dbd6
2020-04-23 21:23:46.052 [vent.ItemStateChangedEvent] - surepetcare_bridge_7f9f20ee_online changed from OFF to ON
2020-04-23 21:23:46.052 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Thing: surepetcare:hubDevice, id: f7d6336e
2020-04-23 21:23:46.056 [vent.ItemStateChangedEvent] - SurePetcareAPIBridgeOnline changed from OFF to ON
2020-04-23 21:23:46.055 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Bridge topology polling job every 36000 seconds
2020-04-23 21:23:46.059 [DEBUG] [nal.handler.SurePetcareBridgeHandler] - Pet status polling job every 300 seconds
2
2020-04-23 21:24:45.113 [DEBUG] [iscovery.SurePetcareDiscoveryService] - Starting Sure Petcare discovery scan
2020-04-23 21:24:45.121 [DEBUG] [iscovery.SurePetcareDiscoveryService] - Starting device discovery for bridge surepetcare:bridge:7f9f20ee
I got the same " Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.devices[1].control.curfew" error.
The JSON response from API contains an object with three attributes:
“control”:{“curfew”:{“enabled”:true,“lock_time”:“19:00”,“unlock_time”:“08:00”},“fast_polling”:true}
I had a look at the code, that just tries to get an array of these informations. I would suggest to check if it’'s an Array or an Object and proceed setting the data the matching way.
I don’t have an environment for openhab to try it,so please help to fix it.
I would like to send a telegeram message if battery is getting low and a few other nice things.
@Oensel, @Osmii, I’ve just committed a fix in the code which should deal with the inconsistency in the JSON API. The binding will now deserialize correctly if a single curfew object is returned as well as an array of curfews.
As my API call always returns an array, I couldn’t fully test it except for a unit test. Please could you have a try with the latest commit.
Thanks,
Rene
Thanks for your quick response.
I tried hard to get eclipse to work with openhab, but failed.
So, I can just test it, if someone builds a compiled jar for me.
Hi Bastian
Here is a compiled version: https://drive.google.com/open?id=1BUMoDO1Nk1MVm8xLwX4ST3OWCr6kRmFt
My household object and the hub are discovered automatically. Just the flap itself throws an exception.
I got this Exception because my JSON doesn’t contain all the data you try to read:
2020-05-01 11:48:17.645 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable
ended with an exception:
at org.openhab.binding.surepetcare.internal.dto.SurePetcareDevice.getThingProperties(SurePetcareDevice.java:71) ~[?:?]
at org.openhab.binding.surepetcare.internal.discovery.SurePetcareDiscoveryService.deviceDiscovered(SurePetcareDiscoveryService.java:175) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) ~[?:1.8.0_222]
at org.openhab.binding.surepetcare.internal.discovery.SurePetcareDiscoveryService.startScan(SurePetcareDiscoveryService.java:130) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_222]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Your Code:
public Map<@NonNull String, String> getThingProperties() {
Map<@NonNull String, String> properties = super.getThingProperties();
properties.put("householdId", householdId.toString());
properties.put("productType", productId.toString());
properties.put("productName", ProductType.findByTypeId(productId).name);
properties.put(Thing.PROPERTY_MAC_ADDRESS, macAddress);
properties.put(Thing.PROPERTY_SERIAL_NUMBER, serialNumber);
--> properties.put(Thing.PROPERTY_HARDWARE_VERSION, status.version.device.hardware);
properties.put(Thing.PROPERTY_FIRMWARE_VERSION, status.version.device.firmware);
if (pairingAt != null) {
properties.put("pairingAt", pairingAt.toString());
return properties;
my JSON:
"id":243375,
"parent_device_id":101922,
"product_id":3,
"household_id":22048,
"name":"Salems H\u00fctte ",
"mac_address":"95D99CFEDFAC3754",
"index":0,
"version":"MjYxMw==",
"created_at":"2019-03-02T14:54:30+00:00",
"updated_at":"2020-05-01T07:51:32+00:00",
"pairing_at":"2019-06-18T19:54:34+00:00",
"control":
"curfew":
"enabled":true,
"lock_time":"19:00",
"unlock_time":"08:00"
"fast_polling":true
"parent":
"id":102753,
"product_id":1,
"name":"Salem",
"serial_number":"H005-0101797",
"mac_address":"0000801F1231B146",
"version":"NzAzNg==",
"created_at":"2018-05-18T11:11:59+00:00",
"status":
"battery":5.864999999999999,
"locking":
"mode":4,
"curfew":
"delay_time":0,
"permission":2,
"unlock_time":"08:00",
"locked":false
,"version":
"lcd":{"hardware":1,"firmware":1},
"rf":{"hardware":4,"firmware":0.16}
"learn_mode":false,
"online":true,
"signal":{"device_rssi":-88.33333333333333,"hub_rssi":-86}
"tags":[{"id":22345,"index":0,"version":"MA==","created_at":"2019-06-18T19:54:42+00:00","updated_at":"2020-03-11T16:06:58+00:00"}]
