Brand new install of Windows 7, fully updated.
Downloaded the Runtime Distro from OH/Downloads
Downloaded and installed Java JRE (More on this in a second)
Downloaded and installed ZULU 10 8.1 8 7
Followed the instructions here: https://docs.openhab.org/installation/windows.html and set my Variable to the Java JRE.
Ran the Start.BAT and then the LocalHost. Chose the Standard Package. Also played around with the Hab Panel a little bit.
After all this, I went back to the instructions to continue where I left off. I checked to see if the directories (found here under File Locations: https://docs.openhab.org/installation/windows.html) were installed per the Windows Installation Instructions.
They weren’t.
This is also where I noticed I installed Java JRE instead of JDK. So, I downloaded JDK, shutdown OH BAT, installed JDK, restarted Start.Bat and then web browsered into LocalHost to see if I can “Re-Install” the Standard Package.
No luck.
I’m not sure what to do from here.
I don’t want to screw this up anymore by trying different things, so I thought I would ask the community!!
