I’ve started a new binding to control the wifi status of my TpLink Router (TD W9970).
This binding uses a telnet connection to command wifi status and monitor several configuration parameters.
An alpha version can be downloaded here:
This binding should be compatible with other TpLink products provided that the telnet interface is identical.
It could be extended to support other configuration parameters (LAN, DHCP,…).
Any feedback will be welcome!
