- Platform information:
- Hardware: Raspberry Pi 4 - 4GB
- OS: Linux openhabian 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
- Java Runtime Environment: OpenJDK Runtime Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
- openHAB version: 3.0.1
Hello guys,
I have had OH3 up and running (new install) for a few weeks now. I was able to add sucessfully items through the Aeotec Z-stick Gen 5 (ZW090), connected to the Raspberry Pi 4 via an USB 2.0 extender, no hub.
All was working fine, I was able to successfully add several Fibaro Wall plugs (Wall Plug - smart outlet with power metering | FIBARO), one POPP smart outdoor plug (POPP Outdoor Plug (700397) - popp.eu) and the last addition a few days ago was a Fibaro Door/Window Sensor 2.
Today, I wanted to add another Fibaro Door/Window Sensor 2, and here the things were not working as expected.
I could see the the Z-Wave stick blinking shortly faster, than a steady blue colour. I plugged back the Z-stick to the Raspberry Pi, waited a few seconds for the controller to be online again… but I had no items in the Inbox. I proceeded to unpairing the device, it was successful according to the colour and behaviour of the Z-stick. I tried to pair again, no luck. I did a reset of the Fibaro Door/Window Sensor 2, and tried again. Still no luck.
I proceeded with another device I wanted to add, a Fibaro Smoke Sensor (FGSD-002 ZW5 v3.3). The same issue occurred. Nothing in the inbox. o_O
Not sure what I am doing wrong… I would like to avoid having to re-install / reset devices.
Any advice?
Thanks a lot.
Cheers
