This is a good hint. The data is already provided by the Z-Way API but is nowhere displayed. I could add two channels to each device (thing): last update from device and last update from Z-Way. However, the properties of the channels would probably be the better solution, but in my opinion, these are nowhere displayed. What would you prefer: seperate channels or channel properties?
I think the conversation and the review of the pull request on Github are crucial. Perhaps there are some testers who write a short experience report in the conversation of the pull requests.
I think the easiest would be to follow (watch) my Github projects: forked openhab2-addons and ZWay-OpenHABConnector
Well, Iām not sure I can suggest something because I quite new to openHAB, but, if you add this as channels I know how to display the timestamp on my sitemap If you add them as properties I think they can only be viewed in Paper UI and/or HABmin.
Hi @pathec, thanks again for this binding.
Iāve been using for some time now and I thought it started to be ready for a merge, but over the last month or so Iāve experienced that OpenHab is not getting updated from Z-way.
Might be something with the OpenHabConnector?
The updates works fine from OpenHab to Z-way, but the other way around only updates on the timed interval.
I cannot find anything in the logs on my z-way-server to check if the connector is working or not.
Any suggestions on how to debug this further?
I tried cloning the Openhab Connector again 2-3 days ago, but the problem is still there.
The strange thing in the view you refer to is that the field called āLast notificationā is old. It is from the end of december, does this mean that the connector has not sent any notifications to openhab since then?
I tried to reset the configuration in openhab, and make sure the name of the OpenHAB Alias is the same in openhab and registered to the connector.
This seemed to trigger a reconnection, but still the āLast notificationā field is not updated.
Yes, does this affect all devices? Will Z-Way show more recent values for the devices?
Please perform the following command once: http://Z_WAY_IP:8083/ZAutomation/api/v1/devices/OpenHabConnector/command/refreshListener.
This should solve the problem one time. Normally this is also done with every change in openHAB. Can you check in the terminal if any errors have occurred for the affacted item or thing for example with: grep "ITEMNAME" /opt/openhab2/userdata/logs/openhab.log (change ITEMNAME to the value from the second column of openHAB connector list).
I have an additional question on one of the channels:
Thermostat operation (24.0)
zway:zwayDevice:11fb7777:24:thermostatMode-ZWayVDev_zway_24-0-64content_copy
The channel allows the control or display of a thermostat (mode). A thermostat can have up to three states (modes): off, heating and cooling. The state of heating and cooling is alternately set at the state on.
The only way here is to define the OpenHAB-item as a String and check the value of it?
Can you also please elaborate when the value will be āHEATINGā, āCOOLINGā or āONā ?
Thatās a problem of Z-Way. Thermostat modes are mapped incorrectly to virtual devices, only as binary switches. An āonā command in Z-Way sets the mode alternately (1 - heating / 2 - cooling) and an āoffā command sets the mode 0 (off). However, many Z-Wave thermostats have several modes. The problem is known and worked on the Z-Way developers.
As a workaround Iāve implemented the thermostat command class as channel (see immage). Here you can set the thermostat mode, e.g. for stella-z thermostats: 1 (frost protection), 0 (energy saving) or 11 (comfort). Note: if the value changes outside of openHAB, it is not updated directly in openHAB, only during a polling. Whether your HeatIt thermostats support the thermostat command class I can not recognize directly from the manual.
What does not work is the command class configuration. Do you change the configuration parameter 12 during the runtime or only once during configuration?
I do have an Aeonlab zstick gen5 as my zwaver controller and Iām stuck, for over 2 months, with initialisation of a motion sensor as discussed here.
Since the problem is within the database of supported zwave devices, which I donāt know how to resolve, Iām considering to use the zway binding instead of the zwave binding.
I have two questions:
Will the Z-Way software license key, work with the Aeonlab zstick gen5 zwave controller?
Does the Z-Way software operate based the zwave database or some other database? (would it support the HSM100 motion sensor?)
Is the binding in the final openhab 2.0 the latest or should I download another one? The roller shutters are all offline (Error occurred when performing polling.)
EDIT: Oh and Iām using 2.3.0-rc10 of z-way becaufe of problems with fibaro dimmer 2
Can you please describe the problem in more detail? The dimmer and binary switch function should work. What virtual devices does Z-Way generate for the Fibaro Dimmer 2? According to the manual, a dimmer, a binary switch and a display for power and energy consumption should be generated.
it was a test because dimmer 2 never completed interview. The rc10 did it.
Back to 2.2 Iāll test your new binding. Thank you and I will tell the result!
@pathec
Hello Patrick!
Any news about adding the ālast seenā timestamp?
Iām using ZWay Binding 2.1.0.201702020955.
Everything else was perfectly!
