Have a strange effect here: had 9 monitors working well in OH, added 2 and deleted 2. Therefore new monitor IDs are 10 and 11. I do not get the “image”-channel working properly in terms of showing an image for the new monitors.
Other than all other (1-digit) monitors, these two are showing a value starting with “```openhab” when hovering the mouse over the item definition before the usual “data:image …” beginning.
Binding version is 2.5.9.202009201420 on OH 2.5.10.
@mhilbush, thanks for your immediate reply and yes, my description is somewhat confusing …
To your questions:
Yes, the Refresh Interval parameter is set. This is the same configuration for all monitors.
Yes, I can see the channels being updated even in the event log like
zm_Gehweg_Image changed from raw type (image/jpeg): 705082 bytes to raw type (image/jpeg): 706813 bytes
I am using Visual Studio Code with the OH extension. Therefore I am able to see the values of a specific item variable when hovering over the variable with my mouse. This value changes for both monitors (10 and 11) as well as for all other monitors.
However, the only difference I see is a prefix “```openhab” as part of the value that is been displayed in the pop-up window.
Not sure if “openhab” was a previous user or password that I defined when using/trying previous version of the binding. I have checked zoneminder config and OH binding config but did not find anything.
This is what I’m seeing when I hover over a Zoneminder image item in VS Code. In this case it’s for monitor 1. Is this what you’re seeing for monitors 10 and 11? If so, I have no idea where this comes from. But I don’t think it’s an issue since all my image channels are working properly.
Sorry, but I’m still confused. Are you not seeing event log entries for the items associated with monitors 10 and 11?
Do you have an item linked to the imageUrl channel? What do you see when you hover over that item in VS Code for monitors 1-9 vs 10-11? It should look like this, and you should be able to put this in a browser and see the image.
Your picture also shows the “```openhab” prefix. Therefore this seems to be normal. However, I did not see this prefix with my other monitors. This is why I assumed this to be not normal. Obviously I was wrong.
Yes, I do see the event log entries, however, the images from this new monitors are not shown in the openhab iOS App.
In the meanwhile I found out that in some cases the images are (partially) visible. I am now investigating performance issues with this monitors/cameras. The cameras are capturing in 4k. This may be too much for the current setup.
Sorry for the confusion.
Let me come back once I clarified the performance topic.
Yes, that does work. I do see the images in the browser.
Please regard this issue as solved.
It was a problem with “imageMonitorId” that was not configured properly for the new setup and a minor performance problem.
I have some trouble with camera cycling with this binding. Please check here.
I have a ZM server with four cameras. I made a setup in OH3 M3-M4-M5-RC1 with a simple rule which cycle 4 cameras switching each 10 seconds. Enabling this rule increases memory consumption in a serious way. Disabling it memory usage not increasing nor descreasing. Can you check if I’ve done something wrong here? Where to file a bug report if it really is?
Sending a command to the Zoneminder server’s imageMonitorId or videoMonitorId channels causes the binding to build a URL for a Zoneminder image or video stream, respectively. It executes this bit of code, which simply updates the Zoneminder server’s imageUrl or videoUrl channels, both of which are channels of type String and contain a URL that can be used to fetch an image or video stream from Zoneminder.
I’m having a hard time seeing how this alone could cause large amounts of memory consumption.
For completeness, can you post the Zoneminder server’s item definitions that you’re using?
Also, can you describe what you’re doing with the URL that you get as a result of the above sendCommand operation?
Thank you for replying so quickly.
I defined all things, items, rules on OH WebUI. So I have no textual definitions of that.
What I do with the VideoURL item is displaying a cycling video on the summary page of OH3 of each cameras inside of an image card. It is also defined within WebUI.
I can confirm that based on J-N-K’s suggestion I unlinked both items from channels and no memory accumulation can be observed.
After 18 minutes the rising noticable. No other rules or bindings currently active in this container.
After an hour of running memory consumption from 930 MB goes up to 1030 Mb (also seend in portainer and docker stats). Not much but after one day it creates noticable slow downs…
I’ve been running this rule for over an hour now. Runs every 2 seconds.
val monitors = newArrayList("1", "2", "3", "4", "5", "6")
var int index = 0
rule "Zoneminder Rotating Video Get"
Time cron "0/2 * * ? * * *"
ZmServer_VideoMonitorId.sendCommand(monitors.get(index))
index = index + 1
if (index >= monitors.size) {
index = 0
@cinadr I don’t know what to make of the issue you’re seeing. I just don’t see how calling ZMServer_VideoMonitorId.sendCommand(id) can cause a large memory leak.
Right now I’m executing my script with a single string item on a fresh docker OH3 container without zoneminder. Memory leak is likely and it is not related to ZoneMinder binding. You’re right. Your script is different from mine. The issue might be connected to Integer::parseInt function or String::format calls inside this script. I’ll test this further. Sorry for your time, and thank you for your testing…
