Last week I included a Zooz ZEN30 into my system and everything included smoothly on the first try and I didn’t see any kind of errors in the logs. The next day I noticed the logs had quite a few of the following warnings:
[WARN ] [otocol.serialmessage.ApplicationUpdateMessageClass] - TODO: Implement Application Update Request Handling of New ID Assigned (64).
It is generated a lot during heals but does show up periodically during the day also.
I searched through the forums and found some mentions of this error but they all had other issues. My device works perfectly, from what I can tell, other than the warning. I waited about a week to see if the issue would sort itself but I still got the error. So, I decided to exclude and re-include the device. Once excluded the warning in the logs went away. I waited a day and re-included the device (Node 30). I started a manual heal of the device shortly after including and the warning returned.
Is this something I should be concerned with?
I’ve attached a link to my log file starting with the ZEN30 inclusion and ending shortly after the nightly heal.
Thanks!
