Newbie having trouble with GPIO on Raspberry Pi
I’m new to OpenHAB and using the GPIO pins on the Raspberry Pi. I set up a simple page up to do an LED on/off test. The page comes up as expected but the LED doesn’t turn on when I select to turn it on. Here are all the steps I took while installing OpenHAB on a fresh install of Raspbian
  1. sudo apt-get update
  2. sudo apt-get upgrade
  3. java -version
    *(java version 1.8.0_65 was installed)
  4. wget -qO - ‘https://bintray.com/user/downloadSubjectPublicKey?username=openhab’ | sudo apt-key add -
  5. echo “deb http://dl.bintray.com/openhab/apt-repo stable main” | sudo tee /etc/apt/sources.list.d/openhab.list
  6. sudo apt-get update
  7. sudo apt-get install openhab-runtime
  8. sudo /etc/init.d/openhab start
    Returned message "[ ok ] Starting openhab (via systemctl): openhab.service."
  9. sudo echo 4 > /sys/class/gpio/export
  10. sudo cp /etc/openhab/configurations/openhab_default.cfg /etc/openhab/configurations/openhab.cfg
  11. sudo leafpad /etc/openhab/configurations/openhab.cfg
    uncommented “gpio:sysfs=/sys” and "gpio:debounce=10"
  12. sudo apt-get install libjna-java
    version 4.1.0-1 was installed
  13. sudo apt-get install openhab-addon-binding-gpio
  14. sudo leafpad /etc/default/openhab
    changed USER_AND_GROUP=openhab:openhab to USER_AND_GROUP=root:root)
    changed JAVA_ARGS= to JAVA_ARGS=-Djna.boot.library.path=/usr/lib/jni
  15. sudo leafpad /usr/lib/systemd/system/openhab.service
    changed User and Group from openhab to root
  16. sudo touch /etc/openhab/configurations/sitemaps/home.sitemap
  17. sudo touch /etc/openhab/configurations/items/home.items
  18. sudo leafpad /etc/openhab/configurations/items/home.items
    inserted the following text
    // Raspberry Pi
    // GPIO
    Switch LED{ gpio=“pin:4” }
  19. sudo leafpad /etc/openhab/configurations/sitemaps/home.sitemap
sitemap home label=“Home”
// Raspberry Pi
// GPIO
Frame label=“Rasperry Pi GPIO”
Switch item=LED
As I stated the page opened as expected but when I try to turn the LED on nothing happens. The following error can be found in the log file
"[ERROR] [.o.b.gpio.internal.GPIOBinding] - Error occured while creating backend object for item LED, exception: /sys/class/gpio/export"
To make sure the LED was wired up correctly I ran “echo high > /sys/class/gpio/gpio4/direction” and it fired right up
Can anyone tell where I went wrong?
install the gpio binding…
That’s what I did in step 13 as far as I know
Finally got it working. After combing through some forums again after a night of sleep I figured out where I went wrong. I guess since I am running OpenHAB as root I don’t need to export the GPIO pins. I just stoped OpenHAB, unexported the pin, started OpenHAB back up, and it worked.
