I just installed OH2 on a RPi. I’ve added a smart switch and have created a rule to turn it on and off at a specified time. So far, so good.
I then started reading the “Beginner” docs and noticed that I needed to create a default.sitemap and default.items file in their respective locations. I have now done that.
I’m completely lost as to what to do next. Any help would be appreciated!
Of cause you have to have the UI installed (install in Paper UI). I don’t get what the problem is, could you describe in a little more detail what you want to achieve?
