New here and to this whole automation thing, so excuse my ignorance if any of these questions have been answered before.
After some time I finally managed to install OpenHAB on my RaspberryPi3
I currently have these devices that I would ideally like to setup with OpenHAB
Blink: Home Security Camera System
TP Link -Smart Wi-Fi Plug HS100
Has anyone used these before and managed to successfully get them to work with OpenHAB? I have been googling a lot and trying to figure it out but no luck.
I did install another OS - Home Assistant (hassbian) on another SD Card and I managed to get these devices working with that very easily.
It looks like there isn’t a binding for either of these devices yet. Someone may correct me if I’m wrong.
Although the TP LINK is fairly simple device. You could get that up and running with the exec binding and pointing the command to a linux script: e.g: this one. and using command="/usr/bin/sh hs100.sh on" bound to a switch.
I did see that link earlier but none of it really made sense to me unfortunately as there was bits and pieces of information rather than a step by step guide. Also some of the links in that thread seem to no longer work
