I verified last Sunday. See?
Sorry - I missed it. If you donāt reply to me, then I donāt get a notification and it relies on me finding the message in the list of new messagesā¦
Iāll have a look.
So the log shows the same thing -:
2019-06-23 09:26:18.377 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:16b83f77166:node3:sensor_temperature to 24.8 Ā°C [QuantityType]
Itās clearly configured as a QuantityType, and is setting the units correctly.
Sorry (Newbie, remember?)
IMO it is more important right now for you to get Zigbee ready for release
Another thought - how have you defined the item? Iām not an expert on the QuantityType, but possibly if youāve not defined the item correctly, then OH may not perform the conversion.
Yes and trying the default units (%units?) gave an error.
Ok, Iām not sure then. Iām not super familiar with the QuantityType - only what the binding does, and from the logs, it is providing a QuantityType with the correct units, so the binding looks fine at least.
Is OH keying off the message before that? It does not show units.
2019-06-23 09:26:18.375 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=24.8
My item (now with my transform) is
Number Outdoor_Temperature "Temperature [JS(tempConvert.js):%s F]" <temperature>
(papillon_yard) { channel="zwave:device:16b83f77166:node3:sensor_temperature" }
No. You should check your events log if you want to see the OH side.
Also, remember that this is working for others here (at least it used to, and Iāve not heard any problems other than with your setup, so Iām assuming itās still working for others). The static unit tests that are run every time the binding is compiled also shows that this is correctly decoding and sending the channel types as QuantityType.
Hmmm - are you sure this is correct for a QuantityType???
Maybe itās worth taking a look at the docs -:
I 'borrowed" a script that just keys off the F
I just changed to try
Number Outdoor_Temperature "Temperature [%.2f %unit%]" <temperature> (papillon_yard) { channel="zwave:device:16b83f77166:node3:sensor_temperature" }
and , after an update, received
2019-06-29 13:00:04.483 [vent.ItemStateChangedEvent] - Outdoor_Temperature changed from NULL to 31.4
and
No units.
Iām not sure what you mean by this?
Iād suggest to read the docs I referenced!
As far as I can tell, your item definition is incorrect - no matter how it was generated. As suggested earlier, youāre not using the quantity type - youāre using a standard number, so I suspect that this doesnāt work for that reason?
Sorry, I missed how to specify a quantity. Looks OK now. Newbie error for sure.
2019-06-29 13:17:28.808 [vent.ItemStateChangedEvent] - Outdoor_Temperature changed from NULL to 88.52 Ā°F
Thank you for your patient instruction.
