Unfortunately this does not benefit to other users.
Whatever the case is then, the database matches what I have in my jsondb.
What channel are you using? I guess itâs not the alarm_raw
, and instead itâs the notification_power_management
? This is not in the database.
Ok, sorry. I was wrong about the jsondb. And sorry I did not update database. I donât think I had access at the time. Here is what is the channel Iâm using in my jsondb:
"acceptedItemType": "Number",
"kind": "STATE",
"uid": {
"segments": [
"zwave",
"device",
"93af1255",
"node85",
"alarm_number"
"channelTypeUID": {
"segments": [
"zwave",
"alarm_number"
"label": "Power Management Notification",
"description": "Power Management",
"configuration": {
"properties": {}
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_ALARM,COMMAND_CLASS_BASIC;type\u003dPOWER_MANAGEMENT"
"defaultTags": []
Ok, so thatâs a different channel again - itâs using the alarm_number
channel that is no longer supported. This was replaced by alarm_raw
as it provides more information.
Iâm not really sure if notification_power_management
has ever been supported in this device and looking at the code, it requires a code change to add support.
@chris Item zwave_device_home_node14_notification_power_management changed to ON
did originally work, even if it wasnât technically the correct way to do things.
However, while I originally didnât seem to get the alarm_raw
output in my logs, after messing with the item type and restarting my server, I seem to get that now, which should be enough for me to figure out how to parse what I need. Looks like it sends this now:
{"notification":"POWER_MANAGEMENT__NONE","level":"0","type":"POWER_MANAGEMENT","event":"0","status":"255"}
I have now updated the binding and the database to add the notification_power_management
channel. This is not ON or OFF though - that doesnât make sense given this is a numeric value with different types of events.
I hope thatâs still acceptable.
Ya, I think that makes sense.
