Next generation design: A Paper UI replacement proposal
Accepted.
Clearly not. See MQTT 2.4 documentation - #15 by crxporter as example why the current syntax is confusing and crap.
And there is really a long heated discussion on textual files that resulted in this design study and I feel personally a little offended by you, that you do no take the time to read this thread (click on “summarize” and you get the picture already) and suggest to use the old syntax instead.
I thought about adding a tab to the item in grid mode. But I don’t really know how to present meta-data and what it is used for. Semantic tagging is done per meta-data isn’t it?
Cheers
