Next generation design: A Paper UI replacement proposal
There is a lot I don’t like about IFTTT, but their recipe builder is kind of nice. Break it up into a sort of wizard flow maybe for the initial creation.
Yannick’s prototype uses a top to bottom arrangement with color coding and a more “yahoo pipes/Node Red” arrangement of elements. So all the triggers go at the top. Then all the conditions, then all the actions at the bottom. Each section is denoted by a different color and sometimes shape.
Speaking of NodeRed, they have a little more free form (I don’t know if Yannick’s is presented top to bottom of constrained to top to bottom).
In both cases I don’t know if I like the need to double click to drill down into each node for the properties. I like the way the parameters are presented right at the top level here, though users will quickly run out of space if they have more than two of any one type.
I don’t know if it needs a frame if you have some other way to show like types. Rules pretty much flow on one direction so position on the graph could do it. Color can do it. Shape can do it. Any combination of the three could do it.
One thing that would be nice though is to have a special shape or color for the “run another rule” action. In that case clicking/double clicking could take you to that other rule. Double clicking a Script Action or Script Condition should open the code editor.
The lines are visually instructive but I’m not sure they are strictly needed. The triggers are going to pass to the conditions and finally the actions. Unless there are constructs in the NGRE JSON Rules I don’t know about that’s all that is allowed.
I’ve spent some time with the current PaperUI UI for this so I don’t really know the full of what’s possible with these Rules.
