Need some guidance.
Have Installed IDE
Created a skeleton.
Developed a working binding.
Compiled it without errors to verify it in my installation.
What is the next step?
/Mike
Need some guidance.
Have Installed IDE
Created a skeleton.
/Mike
That what i said all of this is done.
/mike
Next steps would be:
Thanks.
/Mike
Sorry… I thought you were asking how to get your binding into the distro, and there’s a whole section in the doc’s on how to do that.
Now my GIT knowledge is to low.
Now i have a working binding in my IDE.
Have compiled it and tested it in my production environment.
Now i want to have this up in my GitHub so i can link to the documentation when i release this to Beta testers.
Can i from eclipse do a replica in my Github?
How will this be connected to OpenHAB repository?
/Mike
Did you fork the openhab2-addons repo? Like this?
If so, you should be able to push your local dev branch by doing:
git push origin name-of-your-dev-branch
No i did not create a fork just followed the IDE Installation Guide.
/mike
Now i have created a fork but when i run your command i get an error.
$ git push origin smhi
error: src refspec smhi does not match any.
error: failed to push some refs to 'https://github.com/tnemrap/openhab2-addons.git'
/mike
I’m sorry, I’m not sure what to suggest. I’ve had this setup since I installed the IDE a very long time ago, and it just works. I know just enough git to get by…
This is how my remotes are set up. Perhaps this is not standard anymore, but that’s how it was set up way back…
$ git remote --verbose
origin https://github.com/mhilbush/openhab2-addons (fetch)
origin https://github.com/mhilbush/openhab2-addons (push)
upstream https://github.com/openhab/openhab2-addons.git (fetch)
upstream https://github.com/openhab/openhab2-addons.git (push)
This is my remotes
origin https://github.com/openhab/openhab2-addons.git (fetch)
origin https://github.com/tnemrap/openhab2-addons.git (push)
If I google for your error message the common answer seems to be this error is given when you try to push while you haven’t commit any messages (and/or only added files). I that is the case, as you already mentioned your not very familiar with git, I would advice to learn a little bit more about how git works. There a numerous resources around the internet that teach you how to learn git. That will get you progress much faster than asking help for each and every problem you encounter.
I have searched for some info. regarding this issues as well. I have found this and it seems to be close to what we are looking for. Please, have a look.
http://www.vogella.com/tutorials/EclipseGit/article.html
Br Basse
