I use habpanel on my android tablet with the keypad widget by Murpher.
Sometimes the buttons do not work and I have to click multiple times on a single button until the click has been processed. You can see in the UI that the button has not been pressed when lifting the finger, so I guess it has nothing to do with what is happening inside the ng-click, but seems to be a problem of either habpanel/angular/whatever library.
Everything works as expected when used from the desktop.
Has somebody else seen this and knows how to fix it?
Just for completeness, here is the code that I use:
<div class="widget" ng-form="myKeyPad" ng-init="myCode=''">
<label class="mask"> {{ "**************" |limitTo:myCode.length }} </label>
<table width="97%">
<tr align="center">
<td width="33%"><button ng-click="myCode= myCode + 1" class="numberButton">1</button></td>
<td width="33%"><button ng-click="myCode= myCode + 2" class="numberButton">2</button></td>
<td width="33%"><button ng-click="myCode= myCode + 3" class="numberButton">3</button></td>
</tr>
<tr align="center">
<td><button ng-click="myCode= myCode + 4" class="numberButton">4</button></td>
<td><button ng-click="myCode= myCode + 5" class="numberButton">5</button></td>
<td><button ng-click="myCode= myCode + 6" class="numberButton">6</button></td>
</tr>
<tr align="center">
<td><button ng-click="myCode= myCode + 7" class="numberButton">7</button></td>
<td><button ng-click="myCode= myCode + 8" class="numberButton">8</button></td>
<td><button ng-click="myCode= myCode + 9" class="numberButton">9</button></td>
</tr>
<tr align="center">
<td><button ng-class="{disabled: myCode.length == 0}" ng-click="myCode=''" class="textButton">Löschen</button></td>
<td><button ng-click="myCode= myCode + 0" class="numberButton">0</button></td>
<td><button ng-class="{disabled: myCode.length != config.code_length && config.code_length > 0}" ng-click="sendCmd(config.entered_value, myCode);myCode=''" class="textButton">Eingabe</button></td>
</tr>
</table>
<hr class="separator"/>
<table width="97%">
<tr align="center">
<td><div ng-click="sendCmd(config.alarm_cmd, 'INTERN')" class="activationButton">Intern</div></td>
<td colspan="2"><div ng-click="sendCmd(config.alarm_cmd, 'EXTERN')" class="activationButton">Extern</div></td>
</tr>
</table>
</div>
Thanks,
Volker
