Ng-repeat crashes Layout
I want to use ng-repeat in some template-Widget. Everything works fine, but it crashes my other layout (dummy-, Slider- and
dummy Widgets are not centered
everything ok without template-widget
HABPanel-Dashboard_without_ng-repeat
Graph height is false and slider weight
I simplified the templates as much as I can, but the layout-errors are still there… They disapear if i remove “ng-repeat”.
Any ideas?
Used Template Code:
<div ng-repeat="(id, item) in $eval(itemState('NR_Nina'))">
  <img src="/static/nina/{{item.info.payload.data.provider}}.svg"/>
  <span ng-style="{ color: ({{item.info.type}}=='ALERT') ? 'orange' : 'white' }">{{item.info.payload.data.headline}}</span>
  <span>{{item.detail.info[0].description}}</span>
  <span>{{item.detail.sent | date:'dd.MM.yyyy HH:mm'}}</span>
</div>
