Hey There,
I’d like to do some filtering on a ng-repeat item list. The following two use-cases do work when hardcoding the filter but dont when using a config item for them.
- Loop through all gRollershutters (set in config for groupID) where name starts with
gf_
(for groundfloor)
<tr ng-repeat="item in itemsInGroup(config.groupID) | filter:{name: 'gf_'}">
- Loop through all gGf (set in config for groupID) where item is a Rollershutter.
<tr ng-repeat="item in itemsInGroup(config.groupID) | filter:{type: 'Rollershutter'}">
The above works, but as soon as I try to set the filter to config item to be more flexible, it breaks.
Not working:
<tr ng-repeat="item in itemsInGroup(config.groupID) | filter:{name: "{config.filter_scope1}"}">
<tr ng-repeat="item in itemsInGroup(config.groupID) | filter:{type: "{config.filter_scope2}"}">
Anyone got config based filters to work correctly? Thanks for your help!
Best Sebastian
PS: Would be cool if itemsInGroup
would support nesting (group in group) like getAllMembers
in rules.
