OH v2.5.5 Relase Build
Raspberry Pi3
Hi everyone, I’m trying to configure the NGINX reverse proxy but I have some problems if I want to open BASICUI directly. The schematic that appears in the browser is as follows:
server {
listen 80;
server_name xxx.xxx.xxx.xxx;
location / {
proxy_pass http://localhost:8080/basicui/app/;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
auth_basic "Username and Password Required";
auth_basic_user_file /etc/nginx/.htpasswd;
if I add this:
location /icon/ {
proxy_pass http://localhost:8080/icon/;
icons appear to me but they are huge and keep the whole screen.
Can anyone help me?
Thank you!!!
mstormi
(Markus Storm)
July 14, 2020, 9:29am
#2
A proper NGINX setup is not trivial.
But this is not an openHAB issue so please g**gle for help.
I suggest you move to openHABian , it has a menu option to install NGINX, too (with this config to work).
pacive
(Anders Alfredsson)
July 14, 2020, 10:48am
#3
I would suggest adding a redirect instead:
location = / {
return 301 /basicui/app/;
location / {
proxy_pass http://localhost:8080/;
Requests that exactly match /
(http://xxx.xxx.xxx.xxx/ ) gets redirected to basicui, but all others work like normal.
Hello, first of all thanks for the advice,
I tried to do what you suggested but nothing has changed, I can’t see the basicui icons.
The Nginx configuration works perfectly if you enter http: // localhost: 8080 / then switch to Basicui by clicking on its link. In this way I see everything perfectly. I wanted to avoid this step but I don’t really know how.
I tried everything looking for g ** gle and surroundings but nothing …
pacive
(Anders Alfredsson)
July 14, 2020, 12:46pm
#5
Have you removed the /icon/
location block? Also, just to make sure, have you reloaded nginx after the changes?
Run
sudo nginx -t
to verify your config, and then
sudo nginx -s reload
to restart with the new config.
Yes, I removed the icon and checked the configuration and restarted with: sudo service nginx restart
I also emptied the browser cacke.
server {
listen 80;
server_name My_ddns;
location = / {
location / {
pacive
(Anders Alfredsson)
July 14, 2020, 1:20pm
#7
What address do you type in your browser? Your domain name or your ip address? What happens when you try to navigate to it? Does the address change to include /basicui/app/
Edit: tried with my server and noticed the issue:
It should be
return 301 /basicui/app;
not
(Remove the / at the end)
Ooops … removing the / it works !!
Thanks for all…
When you pass in my part I owe you a dinner !!
Bye
