NGINX problem die to hue emulation
Seems as I’ve been able to fix the fragile system.
  1. use in section 80 no 301 forward, but only the sections from hue emulation manual.
server {
    listen 80;
location /api {
      proxy_pass http://192.168.0.10:8080/api/;
location / {
    proxy_pass                              http://192.168.0.10:8080/;
    proxy_set_header Host                   $http_host;
    proxy_set_header X-Real-IP              $remote_addr;
    proxy_set_header X-Forwarded-For        $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Proto      $scheme;
  1. in 443 section all the stuff can be as desired (I think)
  2. set in hue emulation settings page port to 80 (IP I kept empty, and hue v1 emulation I also left deactivated)
  3. remove from alexa-homepage all smart home devices and search again
  4. call page http://192.168.0.10:8080/api/status/link (or however the IP of the Raspi is) to activate device pairing
  5. all devices were found on my side.
By the way: all entries in http://192.168.0.10/api/status were “no” but pairing still succeeded fine, and
Hue Pages with :80 are still forwarded to https://localhost by chrome (and :8443 by opera) but anyhow all seems to work is fine.
